replace engine
Old Jun 17, 2007 | 01:24 AM
SkyLee's Avatar
So the 5W-30 is better??? or what???
Old Jun 17, 2007 | 01:29 AM
Cody Red's Avatar
always filling [the c]up
i used to use 5w30 all the time, but my last change was to 10w30. I wanted to experiment.
Old Jun 17, 2007 | 07:10 AM
Iam using 5w30 since I think 10 something K miles.
no problem.
changing from 5w30 to 10w30 wont make any differents. at least if u're living in some hot areas.
NoTears316's Avatar
Shock and Awe
I've been using 5w20 since Aug 2003.... same engine, no problems.
Old Jun 17, 2007 | 07:25 AM
CTrx8's Avatar
space for rent
5w-20 here and the question has been asked and answered hundreds of times on here too (as has the devalue of a new engine). that little search button up there isn't just for looks although it looks pretty snazzy.
Old Jun 17, 2007 | 07:30 AM
DarkBrew's Avatar
Extraordinary Engineering
Originally Posted by bjtitan00
Well the engine replacement won't cost me a thing - but does it devalue the value of my car?
Not as much as a dead engine
I'm running 5W20.
Typical engine failures are related more to carbon build up from a lack of revs. This car, after break-in, needs to be redlined every drive.
New engine club
https://www.rx8club.com/showthread.p...ght=new+engine
Recall 4206F
Old Jun 17, 2007 | 08:10 AM
New Yorker's Avatar
They had to replace the engine on my '99 Miata. It actually increased the value of my car a little, as people generally use the number of miles on an engine to determine the mechanical "age" of the car. So… I sold a 12,000 mile car with virtually a brand new engine which, arguably, makes it worth more.
I don't know the answer to the 5W-20 vs 5W-30 question, but I can summarize what most people seem to believe here:
Mazda recommends 5W-30 all over the world, except here, where they recommend 5W-20. The prevailing feeling on this forum is that Ford, who owns Mazda, told Mazda to go with the thinner, more fuel efficient 5W-20 here in order to help bump up fuel economy ratings. (I don't know if that's actually true, but it does seem to be a good explanation for why we're told to use 5W-20 only in N. America.) Some here feel that, while 5W-20 affords you slightly better fuel economy, it does it at the expense of protecting the engine, particularly in hotter climates.
So… reading lots of threads, it seems many feel that, in cooler and temperate climates, at least, 5W-20 is okay. If you live where it gets hot, 5W-30 might be better. Some do 5W-20 in winter, 5W-30 in summer. (Needless to say, there are many opinions about oil: 5W-20 vs. 5W-30, dyno vs. synthetic, to pre-mix or not. Do a search! I'm just giving you the conventional 5W-20 vs. 5W-30 wisdom on this forum which, again, may not even be correct. Though I suspect it is.)
Old Jun 17, 2007 | 10:39 AM
puch96's Avatar
Ford owns less than 50 percent of Mazda.
Honda is also going to 5w20. It's all about fuel economy I guess.
Old Jun 17, 2007 | 11:26 AM
ken-x8's Avatar
What data are you going to gather from that experiment?
Ken
Old Jun 17, 2007 | 03:50 PM
machfive's Avatar
oil
My 8 is new but at my next oil change, I will be switching to Royal Purple 5w-20 synthetic. For more on oil, se one of Rotarygod's posts on synthetics. He is a true synthetic oil guru.
Old Jun 17, 2007 | 04:03 PM
Rich Linder's Avatar
I used 5W30 (Mobil 1 or Royal Purple) synthetic oil in both my RX-7s. One was a Turbo and the other was normally aspirated. Both had well over 120,000 on the original motor and they were both running like new when I sold them. The 13B FC RX-7's didn't have any problem running synthetic oil and I was told by a Mobil engineer that the thinnest viscosity synthetic oil that could maintain adequate oil pressure was the proper viscosity for the engine.
5W30 worked great, year round. I suspect that 10W30 would be fine too, just not as good in the cooler months.
BTW, I seldom had to add make up oil until I had 5,000 miles on the oil. Then, I often changed the oil. I usually changed the oil every six months, regardless of mileage. I have gone a year between changes too, but only when I wasn't driving the car much. I have no problem running synthetic oil for 10,000 miles or more between changes when the engine is in regular daily use.
Old Jun 17, 2007 | 06:48 PM
4me2's Avatar
I have the dealer change the oil, and I don't care what they use.
$25 for oil change and safety check, and wash.
Old Jun 18, 2007 | 08:44 AM
Rems31's Avatar
But you should care since you're gonna have to top up the oil between oil changes...Pleeeeeaaaaase tell me you check your oil level about every other fill up...
Old Jun 18, 2007 | 05:40 PM
typej's Avatar
This scenario is way too common these days, i bet you are honduh or toyoduh guys who just post things like this to scare people away from rx-8.
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
Rx8Lovin
Jul 25, 2015 08:39 PM
dbarber
Jul 25, 2015 01:34 PM
Belalnabi
Jul 17, 2015 07:48 PM
