adjustable suspension?
Rating: Thread Rating: 2 votes, 5.00 average.
Old Jun 16, 2007 | 01:46 AM
Twiztog43's Avatar
Exclamation adjustable suspension?
well i was wondering, if i were to lower the rx8 to an extent where i have to go over speed bumps at an angle or a dip what would happen if it still "touched" the car? is there some kind of suspension for the rx8 that could be adjustable, like changing the ride height, like for example hydraulics? but without sacrificing control and performance of the rx8?
Old Jun 16, 2007 | 02:25 AM
no.
Old Jun 16, 2007 | 04:21 AM
rxAMZ's Avatar
coilovers!
Old Jun 16, 2007 | 08:22 AM
Twiztog43's Avatar
Originally Posted by rxAMZ
coilovers!
ic that they are adjustable, but how are they adjustable? do u have to adjust them by hand before you go driving at certain places with dips or steep roads? or can u adjust them through switches in the car? cause thats what im really looking for
Old Jun 16, 2007 | 08:28 AM
Twiztog43's Avatar
such as hydraulics, but i heard that its not such a good idea because it will result in poor handling and performance. but like those exotic cars such as lambos they have sensors that will automatically adjust the ride height. i just want the one like that except only with buttons or switches, not sensors, because they will turn out to be expensive nor do i want to get under my car and adjust them every time.
Old Jun 16, 2007 | 08:51 AM
Twiztog43's Avatar
maybe such as this one (been doing some reasearch) am i right?
Tanabe Sustec Pro SEVEN Coilovers Mazda RX-8 <font color="#FF0000">Free Shipping!!!</font>
Sustec Pro SEVEN is an all new adjustable coilover suspension that features a wide array of all new circuit developed technology that has not been available until now.
SEVEN advances the technologies and greatest strengths of previous high performance Tanabe suspensions like the RR & DD even further. While similar in appearance, the SEVEN is completely different from any suspension currently available. The difference lies within the suspension itself and its highly unique internal construction and slide valve technology.
The new slide valve technology allows a great range of adjustability and function from both sides of the performance spectrum. (comfort to pure competitive motorsports use)
When used with the new TEAS electronic active suspension controller, the wide range of dampening force is accessible through the touch of a button, and is fully programmable to automatically adjust dampening rates according to the speed you drive.
In addition to TEAS, SEVEN is also available as a special "Hard Driving" version, for strictly motorsports use. (see below)
TEAS stands for "Tanabe Electric Active Suspension" and is the counterpart of the new Sustec Pro SEVEN suspension. This compact unit is the 'brain' behind the highly sophisticated new Tanabe suspensions. TEAS is a fully programmable dampener controller that allows for dampening force to be automatically adjusted while driving. TEAS accomplishes this by connecting and using the signal from the vehicle's Speed Sensor.
Remote dampening control from within the vehicle is not a new concept by any means. In fact, many Japanese vehicles from the 1980's including the FC3S RX-7 and MA70 Supra had buttons to change dampening from "Normal" to "Sport." Unlike other controllers that are simply an update of this older 'analog' technology, TEAS is a much larger step towards highly digital advanced suspension control and tuning through it's speed sensing "Active Mode"
TEAS active dampening control is uniquely possible due to the use of the specialized valving of the SEVEN, in conjunction with TEAS' slim, high speed actuators. These actuators change dampener settings in 1/100ths of a second, which is necessary as TEAS can continuously change settings at different speeds.
Availability: Usually ships in 5-7 business days.
TSE7098padRegular price: $1,980.00padSale price: $1,749.00padModel:
http://www.tanabe-usa.com/coilovers/seven.asp
Old Jun 16, 2007 | 10:44 AM
rxAMZ's Avatar
only damper settings are electronically adjustable, ride height is done manually, but it is a very simple process. just look it up.
Old Jul 21, 2008 | 03:04 AM
solidust's Avatar
its not that hard to change the ride height of coilovers...just make sure to make the wheel gap about.75 inches warren lol
Old Jul 21, 2008 | 03:26 AM
millerlight's Avatar
popasmurff
i have 16 way adjustable coilovers on my 8 and i only scrap goin up driveways or
speed bumps i lov the coilovers i wouldnt go anyother way but thats just me some ppl dont like it but yes u can adjust them but its by hand which is a pain but my damping force is on the hardest setting to so it doesnt bounce and my tires r 225 45 18 and to give u the idea of my drop iam about 2in from the ground once i get some pics done from this guy ull see the drop
Old Jul 21, 2008 | 07:11 AM
Outkast187's Avatar
Owning several cars with hydraulics(59 and 63 Impala) and airbags (64 Impala SS vert, fleetwood lac), I can say you dont want it on the rx8. I am running 155/70/13 tires on all of em, and even with that huge sidewall its not an ideal ride. It can be done, but its a ton of work...my 59 rides better than stock, but it wasnt cheap. When you alter anything on the suspension, it will change it drastically. Go around the bumps....trust me.
Old Jul 21, 2008 | 07:35 AM
Im not sure about your area but Im going to re-adjust it back to stock height. Why ? Cuz NYC roads are "fuxking garbage".
Im just like what maybe 0.25" lower than stock, it has been like this for a while. yesterday, I ran over a bump, my front bumper touched the floor and side marker area snap off. I put it back the way it was with some glue but still ...
duworm
Oct 1, 2015 04:57 PM
To The Wonder
NE For Sale/Wanted
Sep 12, 2015 12:35 PM
TheRedRotor
Sep 12, 2015 07:42 AM
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
