Damn Problem
Old Jun 14, 2007 | 02:19 PM
harash87's Avatar
Unhappy Damn Problem
So my Rx-8 has about 9 thousand miles and every time I break it makes a screeching sound. SO I took it to the dealership and they told me the break pads are 90 % good so I drove it today and the noise is still there. Anyone knows what the problem is so I could take it back and tell them specifically. Also sometime when I pick up to about 50 MPH there is a whirring sounds coming from the car it only last for about 3 second... just wanted to see if anyone has had these problems too. Thanks Guy I think you all are better than any Mazda dealership
Old Jun 14, 2007 | 02:22 PM
nike178's Avatar
go to the tech section.. there must be at least 2-3 posts about break pads squeeling within the last 2 weeks.. Also there is a TSB out for this problem.. check out www.finishlineperformance.com under the rx8 bulletin section..
Old Jun 14, 2007 | 02:23 PM
deadphoenix52's Avatar
meh.
http://www.finishlineperformance.com...01-06-1568.pdf
Old Jun 14, 2007 | 02:25 PM
dmp's Avatar
dmp
RX8 and a Truk....
finishlineperformance has a TSB on Brake Squeal.
Old Jun 14, 2007 | 02:31 PM
Rems31's Avatar
Brake Squeal!
Old Jun 14, 2007 | 02:33 PM
sharkman's Avatar
i had squeeky breaks on my first rx8 and after insisting with the dealership that the noise was not normal they replaced the pads for new ones and neer had a problem after that .
Old Jun 14, 2007 | 02:36 PM
4me2's Avatar
Mine Squeal only when I first apply brakes, only for a few seconds, I wonder if that would be covered?
Old Jun 14, 2007 | 03:29 PM
BlueRenesis82's Avatar
Registered Tracker
break does not equal brake
Old Jun 14, 2007 | 03:31 PM
Rems31's Avatar
you can break the brakes or put the brakes on the breaking.
Old Jun 14, 2007 | 03:45 PM
StewC625's Avatar
Insanely Yellow
I was on my break, so off I headed to Starbucks, where I hit the brake and stopped for coffee. The hot blonde barrista was on her break out in the parking lot working on the parking brake on her shooting brake when she said help me tighten this brake but don't push it too hard or else it will break and then I'll be done with my break but will be broke.
Old Jun 14, 2007 | 04:03 PM
mike73737's Avatar
^^ someone has too much time on their hands...
Old Jun 14, 2007 | 04:05 PM
I got mine fixed using that TSB and they haven't squealed since.
Old Jun 14, 2007 | 04:19 PM
edblor's Avatar
RX-8 Taker Arounder
That TSB is for 2004-2006 model years, but it very well may apply to your vehicle.
Print it out anyway, and bring it with you to the dealer.
G/L,
Ed
Old Jun 14, 2007 | 05:13 PM
OnRails's Avatar
I thought my OEM brakes were loud too until I got some track pads. Now those are annoying on the street!
Old Jun 15, 2007 | 01:57 AM
harash87's Avatar
okay what is TSB? can anybody just please give me a straight forword answer
Old Jun 15, 2007 | 02:10 AM
mikeferz42's Avatar
13BEAST
Technical Service Bulletin. it means a lot of rx8s have this problem, therefore, posted on bulletins for technicians. which translates to your dealership's incompetency for not fixing it the first time. click on the link posted above, the one that says finishline, then you'll know. the whirring sound you're talking about needs more description. do you have the car on full throttle? which gear? a/c on?
Old Jun 15, 2007 | 02:21 AM
if post three does not help, then this is another option..
http://www.zeckhausen.com/bedding_in_brakes.htm
if you cannot figure out where or what post 3 is about it is going to be very tough on you..
Old Jun 15, 2007 | 02:23 AM
and btw,
if you are going to put up a ? like that you need to add year of car, auto or 6sp...
and please put where you are from where your avatar is.
Old Jun 15, 2007 | 02:10 PM
Duke15's Avatar
2006 Velocity Red Mica
I had that problem, took it to the dealer, and they replaced the back brakes. The problem went away for awhile, then came back even worse. This time I went in with the TSB, and they replaced the front brakes. I picked it up yesterday and haven't had a squeal yet (from my car that is). Hopefully it will stay that way.
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
FubarI33t
Sep 28, 2015 08:45 PM
Vedivan1
Sep 18, 2015 12:39 PM
