Clear corners...again
Old Jun 13, 2007 | 11:07 AM
Jethro Tull's Avatar
Living In The Past
I am planning to install the clear corner lenses this weekend, then I noticed that they are not exactly like the amber lenses. Where the forward, fender curve portion flattens-out slightly, the clear lens contour is much more severe, actually concave, whereas the amber lens contour change is more soft and matches the fender contour itself better.
Do I have the wrong lens? Why would the shape be different? Is there a difference between model years?
I've searched for a while and can't find mention of this detail. Any insight is appreciated.
Old Jun 13, 2007 | 11:14 AM
NoTears316's Avatar
Shock and Awe
Where did you get them from? Perhaps a cheap knock-off?
New Yorker's Avatar
You do have the right lens, and yes, the shape is different.
The clear corners have basically two flat surfaces instead of the one curved surface on the stock ambers. I think it's probably because there's a reflector inside, which is used to make it a turn signal in other countries.
Old Jun 13, 2007 | 11:15 AM
edblor's Avatar
RX-8 Taker Arounder
There have been discussion about the 2 kinds of clear corners.
But, 1 kind, the kind most of us have, are Mazda manufactured (or OEMd), and they have the hard angle that you describe.
The 2nd kind are JDM, or another Japanese make, and match the OEM amber more closely.
I bought my clears from Mazda, and they have the hard angle. $40.00 CAD for the pair.
I like the angle on mine Kinda makes the smooth line of the fenders break ever so slightly, but not terribly noticeable until you get up close.
Enjoy yours though!
Ed
Old Jun 13, 2007 | 11:19 AM
StealthTL's Avatar
Metatron
Cool Reflector....
There is a little metal reflector inside - pull it out with some needlenose pliers, or else it will light up funny.
S
Old Jun 13, 2007 | 12:14 PM
Living In The Past
Enjoy yours though!
Ed
Mine came from an eBay seller in Japan, and were packaged in a paper sleeve bearing Mazda labeling. I paid $47, IIRC, which included shipping. At the time there were several sources for these on eBay, I went with the one with the best feedback (100% positive).
Old Jun 13, 2007 | 01:30 PM
S
yup, make sure to take out the reflector or only half of it is going to light up.
Old Jun 13, 2007 | 02:22 PM
BigRed's Avatar
w8nkel
I have the reflectors still in and i think it looks better. when you look at it from the front you still see blue (changed to blue leds) and from the side it looks the same, and from behind it looks normal. i dont know, it just doesnt seem the hassle to me to change. i also dont want to possibly scratch the corners.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
snowrydr01
Nov 23, 2015 09:40 AM
GK1707
Sep 27, 2015 07:33 PM
Stubbs
Sep 27, 2015 04:06 PM
drlubell
Sep 26, 2015 11:58 PM
