"Electronic flasher" for LED turn signals?
Old Jun 12, 2007 | 03:00 AM
Tamas's Avatar
Registered Lunatic
Question "Electronic flasher" for LED turn signals?
This gizmo is offered as an alternative to using load balancers with LED turn signal bulbs (unless I'm mistaken). Am I right?
Is this even the right part to use?
Does this replace something that we already have in the car? If yes, where exactly is it?
Can someone shed more light on this? Any experience with this thing?
Thanks.
Old Jun 28, 2007 | 02:37 PM
BoosTED's Avatar
I believe we have a module that controls our turn signals and hazzards.
I have been looking at this as well and when i went under the dash I couldn't find a flasher unit like the one advertised.
The wiring manual for the 8 shows a module control unit. I couldn't find a flasher unit for the turns listed either.
I had read somewhere that Mazda or some Japanese manufacturers do a different setup for their flashers. I'd be happy to hear that isn't true or that there is an easy work around that doesn't waste energy like the load resistors do.
Old Jun 28, 2007 | 03:59 PM
shazbot28's Avatar
Om nom nom nom
You'd want this:
LED TURN SIGNAL BLINKER FIX - LOAD RESISTOR KIT
http://frickinbrite.com/catalog/prod...roducts_id=113
Old Jun 28, 2007 | 04:29 PM
Spin9k's Avatar
Momentum Keeps Me Going
Although 2 amps will work, you can get by with less - a ~1 amp draw will work by using a 10-15 ohm power resistor and it won't produce quite so much heat. This is what I used http://www.radioshack.com/product/in...entPage=search mounted against the metal of the car as a heat sink.
Total cost $1.59 for two.
Old Jun 29, 2007 | 01:14 AM
NgoRX8's Avatar
^ as long as your capable of soldering or connecting them.
Old Nov 19, 2007 | 03:52 PM
Tamas's Avatar
Registered Lunatic
Yes, that's what I found too, while looking for the flasher. There is a black rectangular module under the dash, close to the OBD-II socket that clicks when the hazard lights are on, so I suppose that's the module you are talking about. Looks like the RX-8 doesn't use such a flasher unit, so the v-leds offering won't work for us
Old Nov 19, 2007 | 03:55 PM
Tamas's Avatar
Registered Lunatic
That's interesting... thanks for the idea. Now just a couple of questions...
Did you use one resistor per turn signal bulb, or just one resistor per side is sufficient?
How exactly did you mount the resistors to the metal, seeing that there is no attachment point provided on it? I guess a good metal-to-metal connection is desirable, so something like using velcro isn't a smart idea, considering the heat that will be generated.
Old Nov 19, 2007 | 04:25 PM
Spin9k's Avatar
You're lucky I take pictures So if one picture is worth 1000 words... two should hopefully say it all ...
Attached Thumbnails "Electronic flasher" for LED turn signals?-led-turn-signal-left.jpg   "Electronic flasher" for LED turn signals?-led-turn-signal-right.jpg
Old Nov 19, 2007 | 04:33 PM
Tamas's Avatar
Registered Lunatic
Heh... that's a cool solution (pun intended)
So, this means that two resistors are sufficient for the four bulbs (one per side), right? That'd be great as I don't feel like trying to mount extra resistors for the front bulbs if I can avoid it.
Old Nov 19, 2007 | 04:42 PM
Spin9k's Avatar
I never thought of that - are you replacing the front turn signal bulbs too? I didn't do that. But I would assume (!!warning lol) that it's one circuit per side, so if that's so, yes one resistor per side (of the car).
I'd just try it and see.
Old Jul 12, 2008 | 12:13 AM
Psychofox's Avatar
我愛台妹,台妹愛我
so i have LEDs in both front and rear. and i only put one resistor on each side, and it still blinks fast.
so does that mean i have to put one resistor in each corner?
Old Nov 24, 2008 | 03:48 PM
Tamas's Avatar
Registered Lunatic
Yes, you'll need one resistor per bulb. I found that out the same way... when replacing just the rear bulbs with LEDs and using one resistor per side, it was working OK. When I replaced the fronts as well, I had to use another pair of resistors otherwise it would be hyper-blinking.
Old Nov 24, 2008 | 06:37 PM
04RX8man's Avatar
Rotary Powered Countryboy
yes!!
Old Dec 5, 2008 | 06:23 PM
BoosTED's Avatar
If a person replaces all with LED they should not blink fast with one resistor per side.
If they are not all changed the bulbs that are incandescent could store up enough energy to cause the LEDs to blink fast.
That is what I noticed when I did the corner marker rewire to enable it to blink like the turn signal.
The power would cause the hazzard light on the dash to light when a turn signal was used.
Old Dec 28, 2010 | 01:01 PM
bergwc's Avatar
After looking at the pin out for the flasher control module for the RX8 it looks like the module has two flasher units (internal) one for left and right. Also looking a standard electronic flasher unit, looks like you could buy two standard units and wire them in to replace the module. Has anyone tried this? Also do you know where a person could purchase a connector that will plug into the wiring harness?
Old Dec 28, 2010 | 02:44 PM
DocBeech's Avatar
I drive at Red Line.
try napa, they have some odds and end connectors.
Old Sep 8, 2013 | 03:24 AM
felgood90210's Avatar
No need to add load resistors
Team
For those interested, no need to use resistors if you modify the relay flasher unit.
Why? Becuase for anyone who has tried to change the front flashers you have a hard time adding resistors due to lack of space.
I have 2004 model Rx-8 and the flasher unit part number is F151-66-830. This flasher may exisit on new models too? I simply changed the capacitor C1 as shown in the pic below from 4.7 micro farads to 10 micro farads and the 'fast flash' you get without the load resistors was fixed It slows down to normal speed.
You can get the capacitor from Jaycar for 40 cents and have any compentent electronics dude replace the capacitor for you.
For those of you who cannot find the flasher unit - it is under the driver's side near behind the dash near the bonnet release. You need a philips screwdriver to remove the bracket holding it. Its a bit fiddly so get a few cushions to support your back as your head gets under the dash
Enjoy
Martin
Old Sep 9, 2013 | 12:07 PM
JamesD31's Avatar
Thanks for the update. I have been looking for a place to swap out the one I bought off of v-leds. So, the true question I would like to know is, take a picture or tell me WHERE under the stupid dash is this module. I have looked plenty of times and am completely lost, even with the wiring diagrams.
Old Sep 9, 2013 | 03:27 PM
viprez586's Avatar
05 RX8 Sold///05 Evo VIII
Awesome work Martin! Should be a sticky!!
Old Sep 9, 2013 | 04:13 PM
firecran's Avatar
Renesis out... REW in
Nice!!
Old Sep 10, 2013 | 06:02 AM
Where is the flasher unit?
Feeling for your here JamesD31 !!! The manual is a bit "generic" in pointing behind the dash near the drivers's steering wheel.
So (recall my car is right hand drive so opposite for left handers)
1. Locate Bonnet release
2. Get your head under Dash - see bonnet release cable
3. Look back at the dash (near the coin holder)
4. There the relay flasher critter - tucked away held by a silver bracket using 1 philip's screwdriver and a locator hole
5. Use a long philips to unscrew (you gotta be a rubber man to do this!)
6. Remember the cushions to support your back as you will be bent backwards over the footwell with your head up inside the dash.
7. DONT try to pull the cable out UNTIL you have released the unit by undoing the phillips screw or you could damage it! Once you have it unscrewed you can pull the unit down to daylight to release the cable.
Here are some pics but as you can see, not a lotta space so hope you get the reference points
PS - I obviously cannot spell OBDC correctly!
Enjoy!
Martin
Prepare to become a compressed person!
Bend your head like a giraffe and look back inside the dash near coin holder
Take a deep breath and find that phillips screw - a torch helps! No daylight here
Old Sep 10, 2013 | 08:15 AM
viprez586's Avatar
Note the above car is not US-SPEC so it will be slightly different and more so on the left side.
Old Sep 11, 2013 | 09:45 PM
JamesD31's Avatar
THANK YOU!!!!!! Finally found the ******, it was so damn stupid, mainly because the bolt was hidden and so I never knew it was that thing!
Anyways, took this flasher module I bought from v-leds.... didn't fit >_> Do they sell actual modules or will I have to customize this ****?
Old Sep 12, 2013 | 05:31 AM
I don't know of any module - like you I just wanted a plug in module.
I bought a spare flasher for $45 from my local mazda dealer and customized that. I am assuming the part number in my original post is the same as yours otherwise once you look inside its usually a resistor or capcitor you modify to make this work (the capacitor was easiest to get at)
I have a soldering Iron so the mod only took me 20 mins
Good luck.
Old Mar 5, 2017 | 08:34 AM
scottmcphee's Avatar
Good luck.
There's a flasher module out now that is a direct fit replacement for F151-66-830, its a flasher that prevents hyperblink of signals if you are wanting to swap signals for LED bulbs.
No need for load resistors, module takes care of it. Does a bunch of other stuff too..
google tapturn
plug and play, plus a fuse panel wire adapter that is also plug and play.
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Evan Gray
Sep 26, 2015 12:30 PM
