Toe-out after tire change?
Old Jun 9, 2007 | 07:00 PM
biotoxin's Avatar
Just swapped my 225 rear tires with 245 after some drift fun. Seems like I need to do a new alignment, bcus the car isnt handling very well. Is this normal? Previous cars I've had, this hasnt been any issue at all.
Old Jun 9, 2007 | 07:10 PM
auzoom's Avatar
Hmmmmmm.........
Yes I find the same thing. I had my car setup for the track with about 2mm toe out. At the end of the day one wheel was at 5mm toe out.
Cheers
Andrew
Old Jun 9, 2007 | 09:30 PM
biotoxin's Avatar
Sad! Why is this happening? Kinda annoying if u want two setups, either she handles lika a bitch on the track or on the street :S
OR spend alot of $$$$$ on alignment each time u need to change rims/tires
Old Jun 11, 2007 | 02:44 AM
your toe setting will not change with a wheel/tire change
new tires need to be scrubbed in before they start handling well
Old Jun 11, 2007 | 06:01 AM
auzoom's Avatar
Hmmmmmm.........
TeamRX8, I dont think he was getting at the tyre change causing it. I think he was saying that the drifting did it. And I find the same thing. Track days and drifting on the skid pan cause my alignment in general to go out.
Biotoxin, a setup who's aim is to handle well on the road will also handle reasonably well on the track. A setup who's aim is to specifically perform well on a track is unlikely to handle well on the road.
gwailo
May 14, 2024 06:57 AM
bullbuchanan
26
Mar 24, 2016 12:37 PM
cschoeps
Aug 6, 2015 12:44 PM
