How to Remove TPM from Stock Rims?
Old Jun 8, 2007 | 12:05 AM
bayarea8z's Avatar
I am new to this forum and usually just "lurk" around and i was wondeirng how do i remove the TPMs from the Stock Rims?
Thanks in advance!
Old Jun 8, 2007 | 12:16 AM
Redpit10's Avatar
G35 Convert
Thats an odd question. You have to remove the tire. The TPMS is the valve itself. On the other end of the fill valve is a box that measures air pressure.
Old Jun 8, 2007 | 12:35 AM
bayarea8z's Avatar
i have already took off the tires, so should the TPMs just fall out if i yank on it?
Old Jun 8, 2007 | 12:45 AM
unscrew the nut on the outside of the rim.. not the valve stem itself... after the nut comes off remover the tpms from the rim...
Redpit10's Avatar
G35 Convert
No. Unscrew the silver piece around the fill valve. After that comes off then I beleive it will come free. Ive actually never done it myself, but I have had the TPMS taken out by a tire place when I powdercoated my rims.
-Beaten to it.
Old Jun 8, 2007 | 12:48 AM
if you need a photo let me know, but it is pretty obvious..
Old Jun 8, 2007 | 03:55 AM
Targatheory's Avatar
Hey, opener, judging by your name you're in the Bay Area, right? Where exactly are you from? I'm at Marin
Old Jun 8, 2007 | 06:11 AM
why would u want to take it out ?
its easy to take it out, but in order to reinstall them you'll need new seals. no good to reuse the old ones cuz if it leaks ....
Old Jun 8, 2007 | 08:04 AM
NoTears316's Avatar
Shock and Awe
You obviously need to take them out if you plan on changing your wheels. That is, if you want them when you install new wheels.
Old Jun 8, 2007 | 08:56 AM
Aseras's Avatar
and be careful, if you put any pressure on the valve stem you can break the damn thing off and it's not fixable.
Old Jun 8, 2007 | 12:36 PM
PUR NRG's Avatar
I've transferred TPMS's several times without problems. Either I've been very lucky or it isn't as big a problem as you think.
________
Ketamine rehab dicussion
Old Jun 8, 2007 | 02:06 PM
bayarea8z's Avatar
i live in San Francisco!
Old Jun 9, 2007 | 12:51 AM
Nice, where do you usually get your car serviced at? I don't want poor quality local shops playing with my car, yaddida mean?
Old Jun 9, 2007 | 07:14 AM
True, its just something like the oil pan's crush washer.
if you're ok, reuse it.
but if it leaks, you will be screwed.
Old Jun 9, 2007 | 07:59 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
My experience would say that you've been lucky to this point.
JimmyBlack
273
Feb 10, 2020 10:23 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Paul_Y
Sep 21, 2015 02:23 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
