price to install springs?
Old Jun 6, 2007 | 05:02 PM
velociti's Avatar
i just ordered a set of tein s-techs for $150...and called a local place that does all sorts of aftermarket installs and was quoted $5-600 to get the install done! is this normal?? I figured that the price of installation wouldn't exceed $200...am I just ignorant or am I clearly going to the wrong shop? Also, any suggestions of where to go in northeast Philadelphia? Thanks.
Old Jun 6, 2007 | 05:23 PM
staticlag's Avatar
The Professor
takes about 3.5-5 hours with air tools, no breaks and getting straight to business. could take 6+ hours if a novice is doing it without air tools. depends on how much they charge for labor. But it seems steep.
But they do have to:
remove wheels, unbolt shock/spring assembly from control arms etc, disassemble spring/shock combo, reassemble with new springs, reinstall, repeat.
Then of course, you need an alignment because you unbolted the control arms. So if they are factoring in the necessary alignment it becomes a bit more reasonable.
Old Jun 6, 2007 | 05:27 PM
LionZoo's Avatar
road warrior
Or you can get in touch with your fellow owners in your region and offer some beers.
Old Jun 6, 2007 | 06:06 PM
NgoRX8's Avatar
keep checking around. they should go from 100-200 w/o an alignment.
Old Jun 6, 2007 | 07:09 PM
pdxhak's Avatar
Official Post Whore
That price is wack. A local shop charged $100 to install my coilovers.
Old Jun 6, 2007 | 08:37 PM
mac11's Avatar
Rotary , eh?
I think i charged like $75-$100 and that included the spring compressor rental.
Old Jun 7, 2007 | 02:17 PM
apotocki's Avatar
When I initially had my Eibachs put on I paid $250. I watched the process and decided to do it myself when changing the shocks to Koni's....its not that hard to do (and I don't have air tools). If you are somewhat mechanically inclined, do it yourself (there is alot of information in this forum in the do it yourself section that really helps). IMO the rears are easier than the fronts so start there. You will need a spring compressor though. I bought one from Murrays for less than $30.
Alan
Old Jun 8, 2007 | 07:34 AM
canaryrx8's Avatar
100-200 tops if you pay somebody, and don't get an aligment right away, drive around a while, let things settle in, then get one. If you do it yourself, it's a lot of work, but the most important thing is rent a spring compressor and see if you can't get someone to help you with it.
Old Jun 8, 2007 | 10:34 AM
altspace's Avatar
Eccentric Shafting
I've always done my own suspension work. If you have a garage or know of someone that can help, it's a great learning process and satisfaction knowing you did it yourself.
Old Jun 8, 2007 | 12:35 PM
balefire's Avatar
SCCA BS #35
Both race shops in my area quoted me $350-400 to install only shocks (almost the same as only installing springs because it requires disassembling the shock). One of the local car guys did it instead for $180.
Installing complete coilovers is cheaper since you don't need a spring compressor and no need to dissemble the shock.
Billy Marcial
Mar 1, 2018 06:50 AM
WingleBeast
22
May 23, 2016 09:22 PM
ableobject
Mar 22, 2016 11:37 PM
FERRET
West RX-8 Forum
Jul 27, 2015 11:03 PM
FERRET
West RX-8 Forum
Jul 22, 2015 02:25 AM
