View Full Version : '90 Non-Turbo Flywheel counter weight
crimson-rain
06-05-2007, 03:39 PM
I'm about to get a clutch and flywheel and was looking at the Findaza flywheel. I read a review for it and it seems to be better than the ACT. The only problem is that it doesn't come with a counter weight. Supposedly the RX-7 counter weight works with the 8 (I still need those stupid bolts from Mazda). Will this particular counter wieght work?
'90 Non-Turbo Flywheel counter weight that is. To be honest, I'm almost thinking about getting the ACT clutch/flywheel combo if this is going to be too much of a headache and pain in the pocket.
chickenwafer
06-05-2007, 03:47 PM
if it fits a 240mm flywheel then it will work
MazsportScott
06-05-2007, 03:56 PM
I would not suggest using the 90 counterweight, a balance issue will most likely follow. I have the required components in stock, 727-530-9960
nycgps
06-05-2007, 04:30 PM
Get Fidanza ! You will not regret it !
(but make sure u're doing at a shop that knows what they're doing, I had mine installed at a local shop and its kinda fuxked up, Im still trying to find a day or 2 so I can reinstall everything myself >_<)
rotarygod
06-05-2007, 04:38 PM
You need the auto RX-8 counterweight. The RX-7 counterweight you are asking about is not the same weight.
crimson-rain
06-05-2007, 06:27 PM
Dang it. Yeah my friend was going to sell me his (a nice hook up) but was unsure too. He works on 7s and has done a good few 8s also. He'll be doing my install.
Oh well, thanks guys. Looks like I'll be holler'n atcha soon Scott.
