Amount of oil...
Old Jun 2, 2007 | 11:53 AM
kalix's Avatar
Amount of oil...
Ok so the manual says to check the oil 5-10 minutes after the engine has been turned off right? My question is, why the dipstick reads higher when checking the oil on a warmed engine vs. checking the oil when the engine is cold. So am I to go with the warm engine check or the cold engine check? Warm engine = oil is over the line, cold engine = just at the line.
I'm just curious because last time the dealership changed my oil, it seemed they filled it just over the top.
BTW I did use the SEARCH...doesn't work that well.
Old Jun 3, 2007 | 10:38 AM
ken-x8's Avatar
The oil level should be the same cold as it is 5-10 minutes after turning it off. That 5-10 minutes is the time it takes for the oild to drain into the pan. Maybe you're seeing a little expansion when it's warm. Are you checking the oil warm and cold with the car in the same spot?
I have yet to have anyone but me - dealer, gas station, Gippy Lube, whatever - fill any car exactly to the line. They always overfill. Dealer has been overfilling my 8 by 1/4 to 1/2 quart. That much would not do any harm.
I wouldn't worry about small amounts of oil. Remember that one usually adds a quart when the level is down by a quart, so that's pretty much the necessary resolution. A lot of us here will top up when the oil is half a quart down, but that's because the mythos of this car includes an obsession with its normal oil consumption, and the dipstick (current version) has a half quart mark.
Ken
Old Jun 3, 2007 | 11:01 AM
staticlag's Avatar
The Professor
are you wiping the dipstick off 4-5 times before taking a reading?
Old Jun 3, 2007 | 01:42 PM
kalix's Avatar
i usually read it after 3 wipes...does 4-5 times make a difference?
and yes, I do check on warm and cold engine on the same level.
Old Jun 3, 2007 | 06:34 PM
staticlag's Avatar
The Professor
fluids do expand when they heat up. I would say its pretty normal.
Old Apr 27, 2008 | 12:21 PM
Jpaul26's Avatar
Full Rotation
Guess my problem's similar, except I added my own oil. Mine was low - near the L. So I added a whole quart about 5-10min after I got home and the thing says its just OVER the F.... I thought the distance between F and L was 1.8 US qt? I'm really hopin its just expansion cuz ur not supposed to overfill these things...
Old Apr 27, 2008 | 01:45 PM
staticlag's Avatar
The Professor
add oil a little at a time
"measure twice cut once"
Old Apr 27, 2008 | 04:41 PM
csl's Avatar
csl
I over filled mine last month, a bit more than the max level. Nothing happen. When you drive for some time, the oil metering pump will reduce it for you and you may need to top up
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
snowrydr01
Nov 23, 2015 09:40 AM
Michael Bryant
Oct 12, 2015 03:07 PM
