using gas with ethanol
Old Jun 1, 2007 | 06:29 AM
haggis's Avatar
boab
Question using gas with ethanol
how much of a problem is it to burn ethanol blended gas in the rotary? In canada more gas stations are selling gas with up to 15% ethanol. The mazda manual says not to use it but the way the market is going I may have no choice. For instance while driving through saskatchewan I had to do to 3 different gas stations untill I found one with no ethanol.
Old Jun 1, 2007 | 06:33 AM
DarkBrew's Avatar
Extraordinary Engineering
Shell Vpower91 doesn't have ethanol (at least in Ontario)
I think that the manual states a limit for ethanol content. You could call the gas co as well because the signs say may contain up to xx%
Old Jun 2, 2007 | 01:32 AM
haggis's Avatar
boab
thanks for the feed back, there is lots of no ethanol gas in b.c. but thr prairies are producing the stuff so it's showing up everywhere. Mohawk gas all have ethanol in it.
Old Jun 2, 2007 | 04:11 PM
AndrewE's Avatar
Yellow Fever
what are ill effects of ethanol?
Old Jun 3, 2007 | 07:15 PM
Aseras's Avatar
mostly ethanol has ~40% less energy content than gasoline, so you loose mileage and power.
Old Jun 3, 2007 | 10:28 PM
All NYC gas has 10% of ethanol in them (I have yet to see a station without ethanol)
they put it in to lower the emission ...
Old Jun 4, 2007 | 12:08 AM
rotarygod's Avatar
Up to 10% or so is supposedly fine. Higher than this and you're on your own.
Old Jun 4, 2007 | 12:27 AM
rg200amp's Avatar
gr8ness
yea, i used to use sunoco 93, untill i saw a sticker on the pump that said gas contains 10% ethanol.
i switched over to shell v-power 93, it has no ethanol, about 2-3 monthes ago, i saw about 30 more miles a tank!
and i feel more power, but im sure thats the mind playing with me.
Old Jun 6, 2007 | 12:31 AM
haggis's Avatar
boab
hi I just read up on all the similar threads on my original question about ethanol use. Lots of good info in there! I was concerned about eating out the seals but as the manual says up to 10 pecent is okay. A mazda mechanic told me not to worry unless it is fuel like Brazil makes. Enviromentaly it isn't any better than high octane gas
Old Jun 6, 2007 | 01:19 AM
MazdaManiac's Avatar
Which is the other bad news about Phoenix gas.
Not only are we limited to 91 octane, we have 15% ethanol universally.
MTBE is long gone...
theblinkof
Oct 4, 2023 05:24 PM
mdl0209
May 23, 2019 05:46 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Zube6115
Sep 30, 2015 12:57 PM
