S2000 rims fit?
Old May 31, 2007 | 10:56 PM
S2000 rims fit?
My buddy is getting rid of his S2000 and will sell me his rims and tires for dirt cheap. They are only three months old and in mint condition. They are Enkei PKR's 18x8.5 rear with Hankook Ventus 245/35-18's and the fronts are 18x7.5 with 215/40-18's. Will the rims fit? If they do can I mount 245/40-18's on all fours even though they are staggered? If the rims fit I think the 215's up front may be too thin. Hell, I don't even know if they fit. The bolt pattern is okay but how do I find the offset of these wheels?
Old May 31, 2007 | 11:05 PM
RA-Eight's Avatar
Scuderia
Bolt patterns the same. S's stock offset is something like +55-60. They will more than likely "fit", but are they preferred, probably not.
Old May 31, 2007 | 11:06 PM
I think the rears only have 24mm of offset. I am still trying to verify. I think the fronts may be 38mm offset and the bolt pattern for the fronts at Enkei's site lists as 5-115. Could the front bolt pattern and the rear be different?
Wilson's Avatar
Peeping over the fence
http://www.tirerack.com/ knows all. Tells all.
Old May 31, 2007 | 11:15 PM
Tirerack does not carry the PKR from what I can see.
Old May 31, 2007 | 11:20 PM
Wilson's Avatar
But they show the measurements for both cars.
Old Jun 1, 2007 | 12:01 AM
Juice's Avatar
I made some poos
If he is your friend then why don't you just try them out to see if the fit?????
I don't want to seem like a dick or anything, but why even post this? It takes all of ten minutes to jack up the car and switch out the front and rear on one side of your car. Then at least you will know for sure, and you can get an idea of how they look on your car too. If he is your friend then you obvioulsy know him and it would only make sense to let you try them on to see if they fit before you buy them.
Old Jun 1, 2007 | 12:05 AM
scsi's Avatar
just for reference, stock offsets are in the 50s and 60s
Old Jun 1, 2007 | 12:08 AM
Maybe because it's easier to ask here then it is to try and fit my jack in the trunk and drive way the **** over to his house and jack up my car in 90+ degree weather and then find they don't fit right or that they could seriously affect the daily drivability. Ten minutes to jack up and swap two tires out with a scissor jack? Are you on a Nascar pit crew or something?
Old Jun 1, 2007 | 12:10 AM
scsi's Avatar
38 will fit in the rear no problem, 24 in the front will stick out a lil bit, if that is in fact the specs
So I don't think they will work, that's a big difference.
Old Jun 1, 2007 | 12:17 AM
scsi's Avatar
i meant stock offsets of the S2K wheels
Old Jun 1, 2007 | 12:23 AM
Oh, so I will check them out this weekend. Think the fronts will be too narrow at 7.5 with a 215? Man, I wonder if I could get the fronts machined down?
Old Jun 1, 2007 | 12:34 AM
staticlag's Avatar
The Professor
usually 8" is the minimum for 245s.
Old Jun 1, 2007 | 03:27 AM
For pre-2005 the OE front is 16 x 6.5 @ 55mm 5x114.3 PCD and the OE rear is 16 x 7.5 @ 65mm 5x114.3 PCD
2005 they went up to 17 x 7.0 front and 17 x 8.5 rear
The S2000 has smaller brake diameters that the RX-8 ... if the offsets are that extreme on the Enkeis they likely won't clear
Old Jun 1, 2007 | 12:53 PM
LionZoo's Avatar
road warrior
Team beat me to it, but just a small correction, but I think they run 63 in the rear; not that 2 mm will really matter. Still, that's a really extreme stock offset and if the offsets you list for the Enkei are true, your friend must've rolled his fender or is getting rubbing since that's more than a inch difference from stock! If you really want this combination (and I wouldn't) I'd put 225/45s in the front and 245/40s in the rear.
Old Jun 2, 2007 | 10:28 AM
His S2000 is an 05' that came with the stock 17" and he is dropped on Teins and it does not rub with the Enkei's. If they fit, I am more worried it will totally screw up the balance of the car and make it unsafe for daily driving. I will use the stockers and the 245's for autox. Maybe I will get them and be able to work out some type of trade or something. I will try them on on Sunday so we will see.
Old Jun 4, 2007 | 12:23 AM
dshiznit1489's Avatar
Formerly Polak Graphics
nope wont fit, hold on let me check now.............................nope they still wont fit sorry.
Old Jun 4, 2007 | 10:11 AM
CosmosMpower's Avatar
1935 lbs. FTW!
You might be able to make it fit with a 15/20 MM spacer.
Old Jun 5, 2007 | 07:31 PM
Update. They did not fit. The fronts stuck way out.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
hufflepuff
May 30, 2016 10:45 AM
Quiggs321
Sep 30, 2015 05:34 PM
GK1707
Sep 27, 2015 07:33 PM
