Need some help - Engine surging
Old May 29, 2007 | 10:52 AM
rkostolni's Avatar
Hey I could really use some help here. I just removed my Greddy kit this past weekend and put it back to stock. It seemed to drive fine. I was on my way to work, was almost there and decided to hammer on it a bit. I floored it up to 8k rpm's and then the power completely died. Now the engine does not respond at all to throttle inputs and it just rapidly revs between 2-3k rpms. It starts right up but immediatly begins this surging. I pulled the codes and found the following:
P0638: Throttle actuator range/performance (Bank 1)
P2109: TPS/Pedal positionsensor a Min. Stop Per.
Old May 31, 2007 | 11:29 AM
rkostolni's Avatar
Problem solved! Looks like the engine sucked up a small peice of plastic that jammed the throttle body. All is good now!
Old May 31, 2007 | 11:35 AM
XRX8X's Avatar
more then a Mazda
i did that some time ago and talk about choking the hell out of your engine!glad you found the cure!
mr. GrandGame
Sep 9, 2025 10:41 PM
vapor2
Nov 3, 2020 03:38 PM
cschoeps
Aug 6, 2015 12:44 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
Rx8Lovin
Jul 25, 2015 08:39 PM
