Does ur 8 burn Less oil after the Recall
Old May 28, 2007 | 12:11 PM
XXXrx8XXX's Avatar
Mazda Mica Grey 2006 GT
Okay after i had my recall 4206 F done i noticed my car burns less oil does it makes sense???? I thought it would burn even more oil since it seals the engine more????
Old May 28, 2007 | 12:14 PM
Starter's Avatar
I premix, and feel safe about it.
Old May 28, 2007 | 12:40 PM
bobf's Avatar
LESS. And I thought I would have to add more. Don't know who to trust. Oh yea, Now I remember, I don't trust anyone.
Old May 28, 2007 | 01:03 PM
RotaryResurrection's Avatar
kevin@rotaryresurrection
As an experienced rotary engine builder, I can tell you guys that the best thing you could do is to premix. If I bought an 8 brand new, from day one I would premix it and probably never have an issue with the car (non-electrical that is).
Since 1989 when mazda switched the rotary to an electrical controlled OMP, they have progressively leaned out the OMP injection ratio and the engines have lasted progressively less and less mileage. They are struggling to meet strict emissions, and keep the engine from using oil in order to help the cars sell. They are actually hurting themselves by doing so because of the bad rap the engines get later when they fail.
I never saw the oil burning of the older engines (no more than 3/4 quart between oil changes in general) as a problem, but clearly mazda continues to try and remove this as a part of the rotary engine.
BTW, premixing helped hot starting and idle stability on my recently purchased rx-8 with 111k miles on the original engine.
Old May 28, 2007 | 02:40 PM
Raptor2k's Avatar
Club Marbles Member
You're RX-8 has 111k miles? I thought the rotary is supposed to blow up at around 20k miles! WTF??!?!
Old May 28, 2007 | 05:14 PM
Yup..I bought it from a 1 owner lady who drove it 100 miles each day to knoxville and back. Still on original engine.
IF you change oil at <3000 mile intervals, flush coolant yearly or bi-yearly, and run sufficient omp/premix lubrication then any rotary can theoretically last 200-300k miles. Even for the older 7's, about 125-150k is the norm.
http://www.rotaryresurrection.com/2n...longevity.html
Old May 28, 2007 | 08:07 PM
NoTears316's Avatar
Shock and Awe
Mine does burn less oil since then.
Old May 29, 2007 | 12:11 AM
Vertigo-1's Avatar
Less oil burned here as well...thought it was pretty wierd myself.
Old May 29, 2007 | 02:25 AM
karstman7's Avatar
i might be missing something...but premix what? oil?
Old May 29, 2007 | 02:52 AM
find the search area..
type in premix.. read read read.. if you have a ? after that send me a pm
Old May 29, 2007 | 02:56 AM
NgoRX8's Avatar
mine burns yes too.. dammit.
Old May 29, 2007 | 03:14 AM
Detrich's Avatar
幹他媽!
YES, burns less than before...
Old May 29, 2007 | 07:10 AM
Trekk's Avatar
Goat rider
Mine also seems to burn less.
Old May 29, 2007 | 07:11 AM
XXXrx8XXX's Avatar
Okay guys we got screwed over by mazda i guess seems like it was a lie in order to meet emissions cause the car burns oil they did a new flash which probably lubes the engine even less seems like it = less emissions and now we are running dry i am pissed if this is the truth and the engine seems to run smoother but i dont get the 7rpm kick in anymore what the hell so was the older flash better how do i premix i am in Canada so what products are good
Old May 29, 2007 | 07:43 AM
Spin9k's Avatar
Momentum Keeps Me Going
Much less after the recall. After a full day of DE where it before used perhaps 1+qt, it was less than 1/2qt. Very surprised.
Old May 29, 2007 | 07:52 AM
Premix baby ! PREMIX !!!!!!!!!!!!!
Old May 29, 2007 | 09:27 PM
PerformRX-8's Avatar
ROTARY-A-HOLIC
I'm not that knowledgable with mechanic terms... but what exactly is in premix?? just so I know, I don't really want to put something in my car that I'm not familar with. thanks
Old May 30, 2007 | 10:50 AM
baseballgenius80's Avatar
WW8P6OLBJD?
Seems like it...I was doing about a quart every 1000 miles, now it is more like a quart every 3000 miles.
Old May 31, 2007 | 09:25 AM
Boostin FD's Avatar
What i've done in the past, at least with the 7, is i just put about 8oz of MMO in the gas tank with every fill up... There are other things that pettit made called protek R that is made for that, but i haven't have any problems with MMO... Then again i'm on the 4th engine in the 7 so who knows....
Old May 31, 2007 | 09:30 AM
If you have/had ride a bike before you should know what it is.
Premix is like a fuel additive, that of course, you have to add it to your fuel. It provides addidtional lubacation for your engine.
The downside is that premix will lower the AKI(Octane) of the gasoline. So if you premix, you might want to use fuel with higher AKI(Octane) rating.
I had some problems with 87 Octane gas + Premix(8oz), but as soon as I switch it back to 93, the problem is gone.
I should try 89 + Premix sometime, but Im kinda lazy.
(I use Idemitsu, by the way)
Old Jun 1, 2007 | 02:10 PM
Duke15's Avatar
2006 Velocity Red Mica
Unlike most of you, mine burns more oil after the recall. However there was another change about 200-300 miles before the recall... my break-in period ended. So I only had one gas tank or so of high revs prior to the recall.
Old Jun 6, 2007 | 01:11 AM
mdw1000's Avatar
I'll snap his neck.
Mine also burns more oil after the recall. 05 AT with about 12500 miles on it.
Old Jun 6, 2007 | 01:37 AM
it all depends on how you drive it..
Old Jun 6, 2007 | 02:24 AM
sleeperx8's Avatar
anti-bandwagon
mine burns way less oil... mebbe from the flash?
Old Jun 6, 2007 | 03:13 AM
MazdaManiac's Avatar
At this point, it appears that mine burns NO oil whatsoever.
I just had a 400+ mile, extremely vigorous mountain run with some very high speed highway sections before and after and I used absolutely no oil.
In fact, I've used zero oil since the new motor went in nearly a month ago.
The OMP is pumping up the feed lines (the bubbles move around and have changed color), but who knows where it goes.
