FINALLY Got it back
Old May 26, 2007 | 11:58 PM
04RX8man's Avatar
Rotary Powered Countryboy
FINALLY Got it back
Hey I just wanted to let everyone know after 24 days in the shop and no loaner car my 8 is back. A bearing on my main shaft broke and tore up all my gears and shifting fork 4 reverse. (I had to tell the mazda mechanic what to check since they had no clue) 6 gears 6 syncronizers, reverse, reverse sync, reverse shifting fork, all springs, main shaft, secondary shaft(I think don't have paper right now) is all what was changed and all under warranty no ?s asked.
Old May 27, 2007 | 12:17 AM
NoTears316's Avatar
Shock and Awe
Wow, what were you doing that screwed your tranny up that bad?
Old May 27, 2007 | 12:25 AM
dshiznit1489's Avatar
Formerly Polak Graphics
learn how to drive stick.
Old May 27, 2007 | 01:36 AM
chickenwafer's Avatar
Nope
that's interesting that they replaced the reverse sync when reverse doesn't have a synchro.
Old May 29, 2007 | 12:09 AM
04RX8man's Avatar
Ok I did nothing but downshift into 2nd at 20mph and it started to rattle/grind on accel! I CAN MOST LIKELY DRIVE A STICK BETTER THAN YOU CAN ANY DAY "DSHIZNIT" SO THAT'S DEF NOT THE PROBLEM. and on the repair slip it say "Rev syncro" so i'm goin by them. How it happened I have no clue all I know is it's fixed and it should b good 4 awhile.
Old May 29, 2007 | 01:45 AM
Cody Red's Avatar
always filling [the c]up
since I have an '04 with a bad 2nd synchro I am preparing for the worst. I have no warranty either. How well would an '06 tranny fit on an '04? Doesn't have a different starter location?
Old May 29, 2007 | 08:01 AM
Are you sure you can drive stick better than dshitznit ?
Old May 29, 2007 | 09:09 AM
NoTears316's Avatar
Shock and Awe
Sounds like a challenge to me.
Old May 29, 2007 | 09:46 AM
StewC625's Avatar
Insanely Yellow
24 days and no loaner car? What the hell is up with that? And why didn't they just replace the transmission unit and be done with it? That would have been a day or two.
Old May 29, 2007 | 11:16 AM
reaper1's Avatar
Because they're Mazda so called Techs.
Old May 29, 2007 | 11:25 AM
mac11's Avatar
Rotary , eh?
I think its odd they have dealer techs rebuilding a trans instead of just swapping it out.
Old May 29, 2007 | 11:27 AM
9291150's Avatar
Got mine swapped out, glad I did. Wouldn't trust most tech's to rebuild my shift boot.
Old May 29, 2007 | 11:30 PM
04RX8man's Avatar
I'm almos positive I can drive a stick better than dshiznit! IDK y they didn't replace it just mazda. I know no loaner car it sucked! Also I had to tell them the prob with was a bearing and then it chewed up my gears and shi$ so at least its fixed and has 500 mile on it already and still goin strong (knock on wood) lol
Old May 30, 2007 | 12:18 AM
NoRotorNoMotor's Avatar
Mazda Only. 10+yrs
I almos pstive hez inz now wayz 'reprzent pennzylvanianz!!!
Wurd that pedalz to da left of da brake be'z da clutchzz!!!
Old May 30, 2007 | 12:26 AM
if it was under warranty a car should have been given... why was it not?
Old May 30, 2007 | 01:41 AM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
24 days without a loaner.
Old May 31, 2007 | 04:10 PM
04RX8man's Avatar
yes in deed no loaner. they kept claiming that they didn't have any and enterprise down the street had no loaners don't ask y but that' how they are. I'm just glad the thing is back but I don't know y they didn't just replace the whole tranny considering they almost replaced everything inside it
05TR1CH
Apr 18, 2023 04:56 AM
Nisaja
Apr 14, 2019 08:04 AM
k4thomas
Aug 5, 2015 03:03 AM
Obivious
Jul 29, 2015 05:57 PM
