RX-8 and Winter...
Old May 26, 2007 | 08:44 AM
Yarrus1's Avatar
RX-8 and Winter...
Hi,guys!I have to use Rx-8 in a cold climate at winter and at hot summers...I wanna know is Rx-8 proplem`s car or not.Cause at special rotary service in Moscow guys tell about often reclamations after winter.And the main problems are:electronical blocks of control,such as ESP,rear...So may be somebody know how to protect?
Old May 26, 2007 | 08:46 AM
NoTears316's Avatar
Shock and Awe
It's not the 8 itself, it's the Potenza tires... they suck. Get yourself a set of winter tires and you'll be fine.
Old May 26, 2007 | 08:54 AM
Yarrus1's Avatar
We use just winter rims with thorns...Like theese...I wanna know about problems with expluatation.If i used Potenza at winter,i`d repaired my cars after 3 days maximum after snowfall.
Old May 26, 2007 | 09:04 AM
Yarrus1's Avatar
I wanna put a plastic panel under the engine like on other cars,but somebody tell that engine will be overheating.So i don`t know what to do...Because i don`t have a warranty,and 20-30% of RX-8 that expluatate in Moscow are have problems with electronics after winters...
Old May 26, 2007 | 09:48 AM
funspork's Avatar
You drive your 8 in Russian winters? damn..............
Maybe a work/ winter car is the best idea.
Old May 26, 2007 | 10:04 AM
NoTears316's Avatar
Shock and Awe
Makes sense. I used studded tires when I lived in Alaska.
Old May 26, 2007 | 10:17 AM
N10S's Avatar
Thats an interesting studded snow tread...what is it? As NoTears316 mentioned I also used studded snows on my vehicles when I lived in Valdez, Alaska and never had an issue getting around safely. That was on a Tahoe though, and the only things you have to consider with the low-slung RX8 is snow depth, grit being kicked-up chipping the window and paint finish, and the risk of other vehicles running into you....
Old May 26, 2007 | 10:59 AM
NoTears316's Avatar
Shock and Awe
I drove a Beretta GT when I lived in Alaska, a little closer in comparison then his Tahoe, but I didn't have any major issues either.
Old May 26, 2007 | 05:09 PM
Lennart's Avatar
What is it with you guys. I drive my car all year around in Sweden, winter and summer, I`e a Rx-8, 4- seat, 4- doors sedan, 6- speed, 231 hp car running as a familycar every day. It doesn`t matter if the temperatur is -30 deg C or +30 deg C, the car has to do her work as well. My Rx-8 get her service every 20000 km and will be washed nessesary or not every year in March.
My car is doing HER jobb very very well and untill now her behavior is very nice. Today she has done 71000 km and the fuelcons. is 12.5 lit/ 100 km.
What more can you expect.
Photo of the car BEFORE waching not after.
Attached Thumbnails RX-8 and Winter...-p1070023-1.jpg   RX-8 and Winter...-p1070024-1.jpg   RX-8 and Winter...-p1070025-1.jpg
Old May 26, 2007 | 05:17 PM
NoTears316's Avatar
Shock and Awe
Holy Carp! You need to wash that thing!
Old May 26, 2007 | 11:04 PM
Winfree's Avatar
From: In the hills between San Miguel and Parkfield - "up in the boonie lands", Central Coast of California, Wine Country
You might consider a battery warmer - frozen and low amp batteries will make your electronics do wierd stuff - you might want to have a more powerful battery installed at the begining of each winter season. Studs on tires nice on ice. Use good antifreeze in fluids... good luck - ours did OK last year in 107 degrees F. , but we didn't do any runs longer than 200 miles at that temperature. Did Ok at 21 degrees F. except for battery weakness - in both piston and rotary cars and also well house battery.
Old May 27, 2007 | 09:21 AM
supergoat's Avatar
I don't "smell good".
But it's not march. He washes it every march.
Old May 27, 2007 | 12:19 PM
Yarrus1's Avatar
My swedish friend is rotary maniacI wash my car every week...And i don`t know how`s his car eats 12 liters per 100km...My car eats 16-21 liters per 100 km...In germany this car ate 12 too...I think that the reason is our petroleum....Cause the consistanse is not so deep like european...
Old May 27, 2007 | 12:28 PM
NoTears316's Avatar
Shock and Awe
That actually looks to be true...
Old May 27, 2007 | 01:00 PM
Lennart's Avatar
That`s true. Photo from Februari 2007.
Old May 27, 2007 | 01:08 PM
Lennart's Avatar
Sofar I have not had any problem with my battery and I don´t drive with studs. It`s more fun drifting with friction tires. I have found out, this car suits me very very well and we have a lot of fun together.
Old May 27, 2007 | 01:10 PM
Lennart's Avatar
I realy like your comment.
Old May 27, 2007 | 01:11 PM
mjcampb's Avatar
My car is doing HER jobb very very well and untill now her behavior is very nice. Today she has done 71000 km and the fuelcons. is 12.5 lit/ 10 km.
Did you attach the front license plate yourself? Looks like you had to drill some holes.
Old May 27, 2007 | 02:03 PM
NoTears316's Avatar
Shock and Awe
That's what I'm here for...
Old May 27, 2007 | 02:35 PM
Lennart's Avatar
Yes I drilled those holes myself. There is to many speedcameras in the Stockholm- area so the front plate has to have an angle of some 60 degree not to be caught.
Old May 27, 2007 | 02:37 PM
Lennart's Avatar
Great, that makes two of us.
Old May 27, 2007 | 08:16 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
One of the dirtiest 8's I've seen. Sad!
Old May 28, 2007 | 04:01 AM
Yarrus1's Avatar
In Russia at winter after one hour of driving you can get your car dirty as swedish car
Old May 28, 2007 | 06:38 AM
NoTears316's Avatar
Shock and Awe
Is that due to road salt or what?
Old May 28, 2007 | 08:02 AM
Lennart's Avatar
Yes, salt and sand mixed together.
