License plate question
Old May 26, 2007 | 06:34 AM
sportrider24's Avatar
Does mazda use a special bolt to hold on the license plate ? I bought my 8 about 6 months ago used. When the dealership put my plate on, it felt as if the bolts they used were not addiquite. The plate wasn't going anywhere so I didn't think much of it. Today I tried to take the plate off as I was issued a new one. When I turn the screws, they do not come out. It's as if there is some kind of nut back there that is turning with the screw. I forced one side and broke whatever is behind the back fender to catch the bolt. Now the plate is just dangling from one side. Any help is appreciated !!!
Old May 26, 2007 | 08:03 AM
NoTears316's Avatar
Shock and Awe
I replaced all the original bolts years ago when I got rid of the dealership plate frame.
Old May 26, 2007 | 08:41 AM
Go48's Avatar
Maybe they're not screws at all, but rather fasteners. There are several different types requiring different removal techniques. One type has a phillips head part that you turn 1/4 turn CCW using light pressure with a screw driver and then use your fingernail around the base of the fastener to pop it out. If that's not what you have, take a pic and post here.
JimmyBlack
273
Feb 10, 2020 10:23 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
