Refinishing the Wheels
Old May 24, 2007 | 09:42 AM
otakurx's Avatar
Rotorheaded Geek
Ok I am thinking about having my wheels coloured black to contrast with the sunlight silver. I am looking for opinions on this, it is a GT with appearance package and I may do another kit at some point. Do you guys think it will look good? Any one good with PS want to take a silver car and colour the wheels black? All opinions welcome
Old May 24, 2007 | 10:59 AM
otakurx's Avatar
Rotorheaded Geek
Bump, come on some has to have a thought??? I would have at least expect someone to say it wouldn't look right or that it sounds niffty. :p
rg200amp's Avatar
gr8ness
hey, whats up. i did the same thing. i painted my stock wheels gunmetal. you can see them on my avaitar.
powdercoat would be the best, but it can take a week or two, so i painted.
what you do is jack up the car, take the wheels off. clean them good with dawn. then scrub them with a mild acid and steel wool, ardex makes acid mag oemwheel cleaner. then scuff them up good with scotch brite. then blow them down with air gun. now give a good wipe down with a grease and wax remover(solvent) let dry good.
now paint. i used duplicolor high performance wheel paint and clearcoat.
paint lightly. use 3-4 light coats, let 20-30 min. pass for dry time in between coats. then do 2-3 coats of clear coat lightly. letting it dry for 20 min in between coats.
then gently put them on the car after a hour of dry time. your good to go. takes like from 6-8 hours.
the key to a great end product is the prep. make sure you prep your wheels GOOD.
get 3 cans of paint and three cans of clear.
Old May 24, 2007 | 11:10 AM
rg200amp's Avatar
gr8ness
its really easy to do. it just take alot of time. i think it would look cool.
but you may want to check out the gunmetal. i dont know why, i was gonna do my wheels black, but i saw the gunmetal and i just had to get me some!!!
Old May 25, 2007 | 07:31 AM
WTWally's Avatar
You might want to check out this thread in For Sale otakurx.
https://www.rx8club.com/showthread.php?t=117624
Old May 25, 2007 | 08:19 AM
NoTears316's Avatar
Shock and Awe
Do you really want to "paint" them, or powder coat them?
Old May 26, 2007 | 08:00 AM
otakurx's Avatar
Rotorheaded Geek
I am actually taking them to a wheel repair shop to have then cleaned up and the color changed. they do look awesome in black, thanks for the pics. The car goes in about a week from now to get it done, I will post the pics up once it is done. I am having them done in a high gloss black, then I am putting some 245's on them instead of the 225's. What is the widest tire some has run on the stock wheels, a friend said I should see if I could go wider then 245.
Old May 26, 2007 | 08:07 AM
NoTears316's Avatar
Shock and Awe
Old May 26, 2007 | 08:08 AM
NoTears316's Avatar
Shock and Awe
^^^ Those are powder coated wet black.
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
duworm
Oct 1, 2015 04:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
xAgyex
Sep 28, 2015 08:54 AM
