Tire wear.
Old May 19, 2007 | 09:34 PM
jtmhjh's Avatar
Tire wear.
Hi. I have 12,000 miles on my '05. Tires are already at the wear bars. I don't drive this car hard by any means. Do you guys typically get this poor mileage out of tires? I have the Bridgestone Potenzas. I had my Mustang for 12 years and generally got 18-20 thousand miles out of a set of tires. That's an extra year the way I drive. Thanks.
Old May 19, 2007 | 09:43 PM
Torchmonkey's Avatar
the bridgestones suck...go to tirerack and look for Avons.
Old May 19, 2007 | 09:50 PM
mysql101's Avatar
tires are not made equal. softer compounds will wear quickly.
the wear rating on the stock tires are something like 80 or 120. My current set are 380 ...
Old May 19, 2007 | 10:04 PM
staticlag's Avatar
The Professor
maybe an aggressive alignment
Old May 19, 2007 | 10:42 PM
Bridgestone does not suck. As OEM I think the RE040 did a pretty good job, I would rather have RE040 than any Good Year like some company uses.
And remember, performance tires will die faster than All season thats for sure.
My Bridgestone have 400 threadwear rating. I beat the crap out of it everyday, its almost like 8K miles no signs of wear, geeze.
Old May 19, 2007 | 11:13 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
The OEM Bridgestones wear very quickly. Check Tire Forum for recommendations and Tirerack.com.
Old May 20, 2007 | 12:09 AM
NoTears316's Avatar
Shock and Awe
My car wears tires.
Old May 20, 2007 | 05:48 AM
Scrapula's Avatar
I have 33,000 mostly highway miles on my OEM Bridgestones. I only just now getting to the wear bars. My main complaint is that the tires are noisy.
Old May 20, 2007 | 09:48 AM
Nopstnz's Avatar
I weared the rears down in 16k miles. Make sure your car is aligned as this will kill your tire wear. Also, the treadwear on the OEM Potenzas is 140.
Old May 20, 2007 | 03:00 PM
PerformRX-8's Avatar
ROTARY-A-HOLIC
im glad you posted this, I was thinking about getting a new set... maybe toyo or I might get mich. all season tires... I don't really like the potenzas....any other advice would be appreciated
Old May 20, 2007 | 05:57 PM
Bridgestone Potenza RE050a Pole Positions
Old May 20, 2007 | 06:32 PM
funspork's Avatar
Depends on your climate. Snow or rain, you need to decide if you want performance or durability.
Old May 20, 2007 | 09:01 PM
StewC625's Avatar
Insanely Yellow
Got 34,000 miles on my "shoes" - Pirelli PZero-Nero M+S still going strong ...
Old May 20, 2007 | 09:36 PM
1.3L's Avatar
Tire wear depends heavily on how you drive your car. My 8 has the stock Potenzas and at 12k miles, they almost look like new. I do hang a few corners every now and then, but not every weekend. At the rate I'm going, my Potenzas should last another 20k+ miles.
1.3L
Old May 20, 2007 | 10:14 PM
do NOT get Toyo Proxes 4 ! do NOT get it.
You get it, you will regret it SOOOO much.
get Avon or whatever else is better than that ****.
Old May 20, 2007 | 10:23 PM
c41250n's Avatar
the treadwear on our stock tires are not that great!
go with Falken
Old May 21, 2007 | 09:09 PM
jtmhjh's Avatar
1.3L
That's amazing to me. How do you get that kind of mileage? I drive to and from work. That's about it. 6,000 miles a year. Have rotated 3 times in 12,000 miles and had 2 alignments. Both times was told it really wasn't needed. I can't imagine my driving is aggressive enough to cause me to get 20k less miles than you. Can't remember the last time I dug into a curve.
Thanks for everyone's thoughts. I'm leaning towards the Potenza 960AS Pole Position. All weather seems to make more sense to me here in WV. We get some snow. Plus the better wear.
Old May 21, 2007 | 09:26 PM
kors-jan's Avatar
Bland is Boring
I've been reading this thread with great interest. I have just under 15,000 miles on my OEM Potenza tires, and the tread wear is very noticeable. Wear bars are showing and my local Mazda dealership said the two front tires have less than 3/32 on them. That's bad, 'cause I don't drive hard. I've been reading all the threads on tires and looking at tirerack.com for recommendations on possible replacements. I think, since I live in SE Michigan and do get below freezing weather and some snow, that I am going to get AS tires this Fall. Am probably going to get Potenza RE960 Pole Position AS -- unless between now and this Fall someone shows me something better (or cheaper). Appreciate everyone's comments and advise -- and especially would like to know where I can get an unbelievable deal on tires, esp the Potenza RE960 AS. Thanx.
Old May 21, 2007 | 11:16 PM
StewC625's Avatar
Insanely Yellow
If you're thinking AS tires and you live in SE Michigan, just go visit TireRack in South Bend, IN - their HQ. They will fix you up. I have had fantastic luck with my Pirelli PZero-Nero M+S all-season tires - great dry handling and performance, stick stays stuck as temps fall, and very good wet handling. Acceptable snow performance especially the first two seasons. Last winter was a bit dodgy as my tires were rounding the 30K bend.
At 34K miles they are getting noisy, have about 5/16" tread left (1/8 above the wear bars). I intend to drive them through mid summer then put new ones on, by taking a pilgrimmage to TireRack in South Bend for them. I paid $150 each for them. Think I might switch to the Avon AS tires for the next round - a little less expensive (about $140 each) and great ratings. Although the Pirelli's have a killer look to them.
FYI, I did a "plus zero" upgrade - up two sizes in section width, down one size in aspect: 245/40-18 vs 225/45-18 stock size. Fatter look = much sharper look.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Michael Bryant
Oct 12, 2015 03:07 PM
duworm
Oct 1, 2015 04:57 PM
