changing wheels!
Old May 19, 2007 | 09:07 AM
skynyrdman's Avatar
skynyrdman
Smile changing wheels!
hi all you 8 lovers, just a quick question , iv noticed alot owners change the wheels on there cars, which i must say when iv been looking at the photos on this site iv been more than impressed with the changes the owners have made, but i wounderd when changing wheels for another make of wheel and maybe a lighter weight of wheel has anybody had a problems!!.
Old May 19, 2007 | 11:10 AM
VRZOOMZOOM's Avatar
VRZOOMZOOM
No problems here, as long as you know the bolt pattern and have centering rings for some aftermarket wheels. If you use a site like tirerack, they pretty much have plenty of wheels that fit our cars without a hitch (also include the necessary hardware like lugs, and centering rings so that the wheels fit right on the hub). Maybe the only thing that i would be concern about is the offset of the wheels which may make the wheel protrude out more or less when its on the car.
Old May 19, 2007 | 11:12 AM
Kane's Avatar
Senior Member
Mine rubbed and I had to get the fenders rolled, but my offset is really aggressive. If you do your homework there should not be any problems.
Old May 19, 2007 | 11:14 AM
llzjayarzll's Avatar
meow
u just gotta know your wheels. read up on tire sizes offsets etc and youll be fine.
Old May 19, 2007 | 01:35 PM
NgoRX8's Avatar
yes, basically when choose a set of wheels you need to make sure:
correct bolt pattern
you clear the brake calipers
you aren't too far out that you'll rubb (unless its enough to fix w/ a roll)
the speedometer isn't changed too much.
oh and that it looks good
Old May 19, 2007 | 06:26 PM
NoTears316's Avatar
Shock and Awe
No problems with mine.
Old May 19, 2007 | 08:00 PM
jskup1's Avatar
The Chief
Also, some wheels aren't compatible with the TPMS.
Old May 20, 2007 | 02:57 PM
skynyrdman's Avatar
skynyrdman
re-changing wheels
thanks guys for the repleys , and the information on the wheels.
Old May 20, 2007 | 06:02 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Check out the tire forum on here.
jay_tibo
22
Sep 13, 2016 08:10 PM
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
bullbuchanan
26
Mar 24, 2016 12:37 PM
mariohardleft
Feb 6, 2016 12:59 PM
dancingdan42
Aug 19, 2015 09:29 AM
