sputter, flash no sputter, 3 hours sputter
Old May 12, 2007 | 10:54 PM
hayasa8's Avatar
like a striped a$$ ape!
I took my 04 with 22k on it to the dealer to check for a newer flash, to clear a CEL, and to find out why I have a cut out feeling 3 times in between 7 and 9k, hung out with tech, he said he didn't know, guessed plugs, told him they were new, he flashed it anyway...drove down the road woohoo...like a striped *** ape...happy smooth acceleration all the way past 9k (whoops) I mean like a rocket...faster than ever before...drove it for about 40 minutes, noticed the high rpm miss faintly and slowly returning...after a day or so it is back as usual, but came on slow...wierd...so in summary new flash meant fast nice running eight with no other changes only to have same old problem return slowly? Searched, read, no info...guess and suggestions welcome. CEL is back on...don't know why yet.
Old May 14, 2007 | 07:16 AM
peterlemonjello's Avatar
Could be your coils.
Old Jun 6, 2007 | 11:13 PM
rxman08's Avatar
it could be the coil.. it is also possible that your mazda oxygen sensor might be bad.. it could also be a vacuum leak, burnt valves, plugs need cleaning and gaping, a plug wire short to ground or the distributor cap or coil shorting.. try to check these things and update us what you observe..
Old Jun 6, 2007 | 11:51 PM
Easy_E1's Avatar
Have we met before, NOT! What the hell are you taking about?
Old Jun 7, 2007 | 12:53 AM
MazdaManiac's Avatar
Usually high-rpm misses are from burned points or bad dwell settings.
Check the wiper fluid and make sure it isn't turning blue. If it is, you might want to go and have that changed.
I don't think it would be the valves, though the valve springs have been known to float at high RPMs.
Adjust your lifters for less lash and see what happens.
Old Jun 7, 2007 | 02:03 AM
paulmasoner's Avatar
Asshole for hire
Old Jun 7, 2007 | 02:09 AM
yes,
and the cel was?????
Old Jun 7, 2007 | 02:36 AM
Originally Posted by swoope
yes,
I think the PID is WTF007.
Old Jun 7, 2007 | 02:41 AM
you will need the lazenby software to fix that...
Old Jun 7, 2007 | 03:51 AM
I prefer the BFH package from Home Depot.
Shankapotamus3
Mar 14, 2021 03:53 PM
TeslaMSI
Dec 10, 2015 01:10 AM
Forevermore
Sep 20, 2015 01:04 PM
