Anyone ever use this?
Old May 11, 2007 | 11:28 PM
http://www.griotsgarage.com/catalog.jsp?&SKU=10122
I saw this in the skymall mag on the plane. Does anyone know if it works? I guess I'll buy it and try, if I get at least 3.5 quarts out then it works right?
Old May 12, 2007 | 01:33 AM
Ever Hernandez's Avatar
Rx8_4eVeR
No thanks, I like to get my hands dirty
Old May 12, 2007 | 01:47 AM
Galen Darkmoon's Avatar
I don't remember
You can get an electric one for half that price. It's about the only way to change oil in a boat with an inboard engine and they do work well too.
Old May 12, 2007 | 02:21 AM
eforer's Avatar
I had to get a topsider from westmarine which is a hand pump metal can version that holds 8 quarts of oil. I got it for my Mercedes. The newer MB's have aluminum oil pans with steel drain plugs which instantly strip out the pans. MB techs are instructed to use vaccum extractors as the drain plug is pretty much a train wreck. The sump in the MB is such that you can get pretty much all the oil out through the dip stick tube using this device. Don't know how it would work in the 8.
I think the topsider is around $30.00.
Old May 12, 2007 | 04:48 AM
https://www.rx8club.com/showthread.php?t=90879.html
still have the bottle sitting in the garage????
Old May 12, 2007 | 06:10 AM
hemmingway_bg's Avatar
I have used this for three years now. Pump about ten times and it goes to work. Warm oil syphons better and faster.
Old May 12, 2007 | 07:37 AM
GerryL's Avatar
Gerry
I use one with the RX8 and several other cars. It works well
Old May 12, 2007 | 07:49 AM
mysql101's Avatar
I like to drain from the bottom, since that's where particulate matter will sit.
Old May 12, 2007 | 08:00 AM
I have fumoto valve so no thx.
and like mysql101 saids, I think I prefer to let the dirty stuff to come out than just sucking the oil.
Old May 12, 2007 | 09:03 AM
NoTears316's Avatar
Shock and Awe
nope
Old May 12, 2007 | 09:11 AM
funspork's Avatar
$25 at Mazda for a oil change and a free car wash. Why bother doing it yourself?
Old May 12, 2007 | 09:21 AM
expo1's Avatar
He's as bad as Can
Myself and others have had Mazda mess up an oil change. If you want things done right, you need to do it yourself.
Old May 12, 2007 | 09:25 AM
NoTears316's Avatar
Shock and Awe
+1
Old May 12, 2007 | 09:33 AM
funspork's Avatar
I have complete faith in the Mazda here. Depends on the shop IQ, I guess.
And if Mazda screws up, they would pay for any repairs, right?
Old May 12, 2007 | 11:16 AM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Just get Fumoto or Fram oil valves.
Old May 12, 2007 | 01:47 PM
eforer's Avatar
With the fumoto, I presume that its fairly easy to open even without jacking up the car. I think I'm going to not bother using my topsider because I have always had the same gunk at the bottom of the pan concerns.
Old May 13, 2007 | 04:25 PM
Thanks Swoope, good write up. I think one if the guys actually demonstated that method at our last meet in Austin. I like changing my oil myself and I have thought about the fact that more sediment would come out through the drain pan but man this would make oil changes even easier. I also heard that Mercedes does it this way so maybe the sediment issue is meaningless.
And no, the ZEX kit has been installed since before vacation. It is the best bang for the buck IMO, but my clutch will not last much longer so that is the next item on my list. For now the bottle sits in the trunk well with the ZEX mounts but the 10lb tank is too big so I am toying with using a longer but way thinner chrome oxygen tank that I found in storage at work but I need to find out if I can attach the valve from my zex bottle to it. No rush but I will post pics once it's mounted permananty. I want to get it dynoed first and then i will head to the track.
Old May 13, 2007 | 04:36 PM
lurch519's Avatar
www.evoperform.com
funny, my father was doing the same thing 25 years ago on his boat. had a 23 foot fiberglass boat, chevy v8 inboard with volvo penta outdrive. had a little pump that he would connect to a drill motor, stick the hose over the dipstick tube, put the other hose in a container, and start the drill spinning. oil was out of the engine in no time.
