Stock Fuel Pressure?
Old May 11, 2007 | 08:31 AM
jskup1's Avatar
The Chief
Can someone with a fuel pressure gauge tell me what their pressures are at idle, cruising, and WOT? I think I have an issue with my cabling and want to find out for sure before I start T/S.
Old May 11, 2007 | 06:19 PM
jskup1's Avatar
The Chief
How did I know you would be the first response. I almost just PM'ed you instead of posting. Mine reads about 59 and is pretty much constantly there, even when I first turn the ignition to "on" and haven't started it yet. I see it move about a psi or two at times but that is it. I was thinking while the engine was running, it was okay, but that I should see a drop with the engine off. Thanks though, you saved me from taking my dash back apart.
Jon
RevMeHarder
Jun 1, 2026 02:30 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
DVerdeyen
Sep 29, 2015 10:31 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
