Engine check light on my 2007 Rx8 already!?!?
Old May 9, 2007 | 06:11 PM
Alano's Avatar
07 Phantom Blue Owner
Well my Check Engine light just came on and I only have 187 miles on the car. I mean I didnt do anything wrong to the car except stall a few times. Its really bugging me, car feels fine, anyone else encounter this problem?
Old May 9, 2007 | 06:16 PM
Huskyfan23's Avatar
It's probably nothing. Did you just fill up the car and not tighten the gas cap? That's a common reason the check engine light goes on.
Go to your local dealership. They shouldn't charge you anything, and they can do a computerized engine check in like 5 minutes.
With 187 miles on the car, I really would be shocked if anything was actually wrong with your RX-8.
Old May 9, 2007 | 06:17 PM
puch96's Avatar
try resetting the computer. Also check that your gas cap is closed correctly.
Old May 9, 2007 | 06:21 PM
puch96's Avatar
[QUOTE=Huskyfan23;1870262]It's probably nothing. Did you just fill up the car and not tighten the gas cap? That's a common reason the check engine light goes on.
With 187 miles on the car, I really would be shocked if anything was actually wrong with your RX-8.[/QUOTE
Yeah... nothing is wrong with your car
RoXanneBlack8's Avatar
stop flooding ur engines
gas cap is numero uno on this one chap!
at 187 miles u should be on ur third gas tank or so so u must have filled it and then not tightened the cap enuff. if it is tight, check the tether on the cap. if there isnt a yellow dot on the end of the string....go to a mazda dealer and tell them about the check engine light....there are updated gas caps.....it involves multiple mazda models.....
or the CEL could be literally nothing and a simple reflash will fix it....whatever! hahahaha!
Old May 9, 2007 | 06:53 PM
Alano's Avatar
Theres no yellow dot on the string, a previous owner had the car, for 75 miles, didnt know how to drive stick, so he turned it in. I put the rest of the miles on it, still havent filled a gas tank yet, Im almost out, but havent filled yet, so it cant be that. Its just really annoying because my Audi S4 constantly had the check engine light on, I just wanna drive without seeing that ugly yellow light...damn man.
Old May 9, 2007 | 07:09 PM
Huskyfan23's Avatar
It's seriously probably nothing. Even if the guy didn't know how to drive stick, I don't see how seriuos wear and tear could happen in only 75 miles (he must have been cruising in gear for most of that). Go to the shop........they will be able to do a quick diagnostic and tell you why the light came on (and tell you what steps to take to make sure it doesn't come on again)
Old May 9, 2007 | 07:51 PM
Alano's Avatar
Ugh. I just really hate seeing it there, I saw it ALL the time in my S4, its just an ugly sight..
Old May 9, 2007 | 09:07 PM
Just go try to secure your gas cap
but I have a feeling its the Gas Cap TSB. You can bring it to your Mazda dealer, tell them you have CEL, maybe the Gas Cap TSB. they will replace it for free (its a known issue for 07s)
Old May 9, 2007 | 09:09 PM
Alano's Avatar
You sure its the gas cap? I made sure it was tightened and I clicked it plenty of times. Could it still be the problem? Im going to try to take it tomorrow or the day after, its too far of a drive for me since I still dont know manual well, I need to find someone to come with me
Old May 9, 2007 | 09:35 PM
NoTears316's Avatar
Shock and Awe
If she never put any gas in it, I doubt it would be the gas cap. Take it to the dealer tomorrow.
Old May 9, 2007 | 09:36 PM
Alano's Avatar
He* My avatar is actually my girlfriends eye lmao.
Old May 9, 2007 | 09:40 PM
funspork's Avatar
She only has one eye?
Old May 9, 2007 | 09:45 PM
NoTears316's Avatar
Shock and Awe
Oh... I thought you were a woman. I'm gonna start treating you poorly now.
Old May 9, 2007 | 10:01 PM
Alano's Avatar
Better then thinking I'm a woman I suppose...
Old May 9, 2007 | 10:07 PM
Easy_E1's Avatar
Just take the car to the dealer and say "FIX IT" Get on with it.
Old May 10, 2007 | 10:29 AM
TimzSI's Avatar
My PB 07 had the same issue at around 500 miles. Took her in, dealer did the free "Mazda passport check" or whatever and replaced the cap assembly. No re-occuring problem since, 4500 miles later. Freaked me out tho! Especially since I always use the three clicks technique.
Old May 10, 2007 | 11:35 AM
alnielsen's Avatar
When I got my car, I had a CEL within a week. I think it was a missfire problem. That was a while ago.
Old May 10, 2007 | 12:48 PM
dmc27's Avatar
doin' the bull dance
lmao!!! He's so not going to get away w/all the n00b stuff that has slid so far.
Mine went on one day. I called the dealership and set and appt when it was still on the next morning. By the end of that night it went out and I cancelled.
Search the gas cap issue. (tho I can't understand how the f8ck it is still an issue on 06 or 07 models.)
Old May 10, 2007 | 01:27 PM
Kane's Avatar
Senior Member
My 07 did the same thing at about 450 miles or so, it was a loose connection somewhere, dealer fixed it no big deal.
Take it in, it will be free and should be quick.
Old May 10, 2007 | 01:53 PM
Alano's Avatar
Regardless, it shouldnt be a problem bad enough that I shouldnt drive right? Im taking it in tomorrow. Thanks guys..
Old May 10, 2007 | 02:04 PM
elite8's Avatar
I was actually goin to make a thread like this also... I took my car to a local auto shop and it said the reason the check engine light was on, was because of low voltage...
Can anyone give me any explanation to this?? Thnx
Old May 10, 2007 | 02:07 PM
You dont really have to refuel to get the CEL
Its that cap that has a seal problem. so it will still leak even u never touched it b4.
Just take it in and say WTF DUDE FIX IT !
Old May 10, 2007 | 02:08 PM
Low Voltage of what ? It will be better if he can tell you the *actual* code, so you can look it up in the service manual.
Old May 13, 2007 | 12:13 PM
NYC Drift King's Avatar
Supercharged by Pettit
hey i bought a 05 gt with 16, 000 miles, i have been drivin it kinda hard do you guys think it could be my cel too? I've put like 600 miles on the car already.
