ndtechie09
05-01-2007, 10:18 PM
I have a Racing Beat SS Clutch line and I'm looking into getting SS Corksport Brake Lines and then flushing the system with ATE Super Blue. I've been told by a friend of mine that my peddles feel very good and that I shouldn't change anything out because of the change to f things up with the feel of the peddles. Besides the possibility of air getting in the lines which I'm attempting to not get in because I'll be using a power bleeder, does anyone see any possible drawbacks to this?
-Brett
chickenwafer
05-01-2007, 10:22 PM
since you're using high qualitly pieces, I doubt it will have an adverse effect. It will make you pedal feel better and your lines will last longer. Not to mention they won't expand as much as stock rubber ones, giving a better pedal feel and feedback
Phantom Menace
05-01-2007, 10:23 PM
No. SS lines only improve response and feel. The only way you can FUBAR this mod is by not bleeding the breaks right and putting air bubbles--which you already recognize as a potential hazard. If you do it right, there is no draw backs on this mod. Well...maybe rubbing of the lines against suspension components and the insides of your wheels. Just clamp them in good and test the lines and full turn (right and left) and you should be okay.
Hope this helps.
EDIT: Damit Chicken...you beat me to it! You must type really, really fast!
