View Full Version : rusty rotors?
joebennz 04-27-2007, 02:37 PM are rusty rotors covered under warranty?... i checked the Rosenthal service bulletin but didnt find anything. when mazda did my brakes they got the rust off the front wheels but not the back wheels... when i brought it back they said the backs werent covered under warranty
joebennz 04-27-2007, 02:38 PM by covered under warranty i mean sand and/or paint the rotors, not replace them
Raptor2k 04-27-2007, 02:44 PM Some dealerships paint them, some don't. If not, not hard painting them yourself. Could paint your calipers while you're at it.
myriadshalaks 04-27-2007, 04:11 PM i've noticed this on mine too. will paint not just wear off in a week?
Not if you prepare the metal properly and use a good high-temp caliper paint like G2. The key is getting all the rust and any oil or grease off before you paint. They should be squeaky clean before putting a brush to them.
mysql101 04-27-2007, 04:46 PM i used cheap paint the first time around (from walmart), they lasted about 2 years.
I used G2 since then, and that stuff is definitely going to last longer
joebennz 04-27-2007, 05:41 PM oo.... i painted my calipers but i dont noe how to remove them to get the the rotor thats y i wanted the dealer to do it
Phantom Menace 04-27-2007, 05:45 PM are rusty rotors covered under warranty?... i checked the Rosenthal service bulletin but didnt find anything. when mazda did my brakes they got the rust off the front wheels but not the back wheels... when i brought it back they said the backs werent covered under warranty
Most brake rotors, including Brembo, are made of ductile iron. Iron rusts. Some companies put a zinc coating on the rotors, but since rotors are a "wear-part" the Zinc will eventually wear off and you will be left with bare iron. Iron oxidizes (rusts) in just about anything except in a vacuum. Learn to love 'em. If you can't live with rusty rotors, then "bed" your pads in every time you see rust. You will go through pads/rotors really fast but no more "rusty rotors."
I think he's referring to the hub of the rotor, not the braking surfaces. Only way to get rid of that rust is to remove it with sandpaper and/or a rust remover chemical.
joebennz 04-29-2007, 09:51 PM yea its the hub that has the rust... when the braking surface of the rotor gets rusty it immediately comes off when i drive the car.. i thought that the dealer was suppsed to paint them if they rusted.
Subdivisions 05-01-2007, 10:27 AM Your warranty “might” cover the repair/replace.
Here was my experience …
I purchased my ’04 MT used last summer with 11,000 miles from CarMax.
Before I took delivery of the car, I pointed out to the salesperson that there was surface rust on the rotors and wheel hubs. The dealer told me it was because the car had sit on the lot for a while, and will be taken care of when they “clean” the car.
When I came back in a few days to pick up the car, the rotors and hubs were still rusted, although not as bad. The dealer at this time said it will rub off under normal driving. I told her not around the wheel hub. She said to take delivery and if I wasn’t satisfied, to bring it back. I knew this would be the case, but took delivery.
The dealer was partially correct … some of the rust on the rotors did rub off, but not all. As expected, the wheel hub rust did not change.
Long story short … I went several rounds with the CarMax dealer, even got the sales manager and service manager involved. The sales manager said “This is an appearance issue, I won’t replace/repair the rotors for an appearance issue”. My reply of “But your salesperson said this would be resolved” was not enough.
I decided to fit the bill for repair or replace, but I wasn’t going to let CarMax work on my car. I took the car to a local Mazda dealer (now my permanent dealer), and my warranty paid for 4 brand new rotors and mounts. I could have saved myself several weeks of grief if I had only started at the Mazda dealer.
The moral of the story … Finding a good place to have your car serviced can be difficult. Another moral is … Don’t take delivery unless you are completely satisfied.
I realize that some Mazda dealers are better than others are. This might be “my” dealer, and not common. I would definitely discuss with your Mazda dealer, especially if you purchased from that dealer.
Socr8tes 05-01-2007, 11:22 AM My exhaust pipe is starting to show a little rust. If I argue enough with the dealership, do you think they'll sand and paint it for me?
marvin_rock 05-01-2007, 11:32 AM I hate to throw a search out there, but I just don't remember the link for it. There is a TSB out about it, and it's still a "sometimes" situation. But I've had the dealers do it for me.
strokercharged95gt 05-01-2007, 12:50 PM This is what you need... POR15 is the shiznit for doing undercoatings for show cars.
http://www.por15.com/
corners 05-01-2007, 01:21 PM Well, I wouldn't use POR on a show car, but I used it on my old '55 Willys Jeep to paint the frame and rollbar. It holds up well, although if it exposed to direct sunlight it needs a topcoat to keep it from fading.
Socr8tes 05-01-2007, 01:24 PM This is what you need... POR15 is the shiznit for shortcuts and half-assed jobs.
Fixed. ;)
