Down shifting
Old Apr 24, 2007 | 05:12 PM
mattvit's Avatar
Down shifting
how much does down shifting wear out the clutch, if done properly?
Old Apr 24, 2007 | 05:17 PM
DarkBrew's Avatar
Extraordinary Engineering
If you can match the revs exactly then it doesn't cause any wear. You also should worry about rev matching to protect your synchros
Old Apr 24, 2007 | 05:22 PM
Paul_in_DC's Avatar
Rotary Public
^ What Dark said. I downshift all the time, and I have a 15-year-old Toyota Celica with 180,000 miles and the original clutch. Match revs when you downshift and the effect on the clutch is minimal.
Old Apr 24, 2007 | 05:27 PM
Raptor2k's Avatar
Club Marbles Member
...it doesn't.
edit: bah I had this thread tabbed in firefox for about 10 minutes, whatever
Old Apr 24, 2007 | 05:32 PM
mattvit's Avatar
thanks for the info, but what i should have specified was without rev matching....like using the engine comprssion to slow down, that type of down shifting
funspork's Avatar
Down shifting at 70mph to third gear, and flooring it, puts a smile on my face.
Old Apr 24, 2007 | 05:41 PM
rotarygod's Avatar
Downshifting does not add any appreciable amount of wear to the clutch. That is a myth. Does it add any? Sure it does. Will it effectively reduce the life of your clutch? It depends on how you drive. I'm at 158,000 on my daily driver and I downshift everywhere. I'm so crazy about downshifting that I'm still on the original set of rear brakes. No clutch issues.
Think about this. When you are downshifting, all you are doing is increasing the speed of a rotating engine assembly. It isn't under a load and relative to the car doesn't weigh very much. It's just dead weight you are slowing down. This isn't that hard. When you are accelerating, this engine is under load providing all of it's power through the clutch and is trying to get 3000+ pounds moving. Sometimes quite quickly. Sometimes people will dump the clutch at high rpms and really put some power through the clutch. Of course this is the fast way to kill it but it usually does it. Downshifting is nothing to it. I don't rev match. I slowly ease into the clutch until the engine's rpms get where I want. I use the engine as a dynamic brake. It works great and saves fuel and brakes. It doesn't do anything appreciable to the clutch.
Old Apr 24, 2007 | 05:43 PM
Raptor2k's Avatar
Club Marbles Member
^me too
I guess you mean engine-breaking...I do it sometimes, but not often. I don't see the point. Wear is put on your clutch and synchros whenever you use them. During engine breaking, you're using them a lot, even if you're doing it right. It probably doesn't hurt your car too much...but I'd rather use up my brake pads.
DarkBrew's Avatar
Then take what I said before and apply the contrary
Figure out heal 'n' toe down shifts.
Old Apr 24, 2007 | 05:54 PM
mattvit's Avatar
i already do, but thanks for the tip.
Figure out heal 'n' toe down shifts.[/QUOTE]
Old Apr 24, 2007 | 09:35 PM
tony_673's Avatar
...is it over yet?
Downshifting also reduces brake dust.
Very important after an hour or two washing and waxing the car.
Old Apr 24, 2007 | 09:39 PM
Cody Red's Avatar
always filling [the c]up
I don't match revs either, I do the same.
-Cody
Old Apr 24, 2007 | 09:42 PM
Mu ha haaaaaaa
Old Apr 24, 2007 | 09:53 PM
Krankor's Avatar
Klingon Grammarian
Likewise. Never had a clutch problem. My day is made that I'm doing the same thing as rotarygod! As I've said many times, your clutch is not made out of crystal.
Old Apr 24, 2007 | 09:56 PM
mysql101's Avatar
I'd venture to say that shifting is at least 50% of what makes driving the rx-8 fun.
Old Apr 24, 2007 | 09:59 PM
Cody Red's Avatar
The other 50 is tackling the twisties .
-Cody
theblinkof
Oct 4, 2023 05:24 PM
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
XianUnix
Sep 29, 2015 03:48 PM
