Underbody Light Install
Old Apr 23, 2007 | 01:58 PM
Blacknoir's Avatar
6SPDUFO
ok, I know these things are super ricey and I would never ever EVER get one.. cause I wouldn't want to be called ricey..
But let's say I have this friend.. not really much of a friend since he's doing this.. but regardless. He has, oh, let's say an 04' rx8.. and he wants to add the Blazin LED kit. He has a couple questions for those of you other posers out there that might have done this.
Where did you run the wiring up into the car?
Did you run any wiring over the exhaust, and if so where did you do it?
Thanks,
Blacknoir.. wait.. I mean 'friend of BlackNoir'.. yeah.
Old Apr 23, 2007 | 02:32 PM
shazbot28's Avatar
Om nom nom nom
I don't think running wire over the exhaust would fly at all. It'd either: a) melt or b)burn
For the wiring of the car, I'd think you could tap into the trunk wiring?
dshiznit1489's Avatar
Formerly Polak Graphics
fail.
Old Apr 23, 2007 | 02:40 PM
Blacknoir's Avatar
6SPDUFO
yeah, it would melt. An install site I looked at said you need to run the wires from Side A to Side B, going over the exhaust in a some sort of safe manner. Otherwise you need to find 2 inputs, 1 on each side of the car... hmmm..
Old Apr 23, 2007 | 02:53 PM
Aero8's Avatar
when I had underglow on my [vehicle not to be named here] I ran power directly to the battery. I had the wires coming straight up into the engine bay from underneath the car. One wire on one side and then two wires (side and the rear) coming up the other. along with the front coming up. the rear I was able to run the wire high enough over the exhaust to where it wasn't affected. Don't know if that will help at all, but good luck. I have't seriously looked at puting underglow on the 8, so I am not sure of the best routes.
Old Apr 23, 2007 | 02:58 PM
Blacknoir's Avatar
6SPDUFO
That's a good idea.. I think doing rear up the trunk and the rest up through the engine bay would work as long as the wire was long enough.
Old Apr 23, 2007 | 03:08 PM
chickenwafer's Avatar
Nope
If you get power from the trunk light- you're underglow lights will only come on when your trunk is opened! I would recommend not doing that
Old Apr 23, 2007 | 03:10 PM
Blacknoir's Avatar
6SPDUFO
That would be bad. No, I meant just running up through the trunk and then once inside the car running it through to the ecu for the kit. Every light bar has to run to the ecu which then has a wire to the battery.
Old Apr 23, 2007 | 03:30 PM
laythor's Avatar
I zoom therefore I am.
perhaps you could talk your friend into just taping a whole mess of road flares under his car? would give the same effect with the added bonus of not having to wire anything.
all kidding aside (i wasn't kidding btw)
tap into the battery and run a line from there down both sides of the car. run a leg to a switch in the cabin so you can rice and de-rice the car at your (his) leisure.
Old Apr 23, 2007 | 03:40 PM
Blacknoir's Avatar
6SPDUFO
But do they make multi colored flares?
Old Apr 23, 2007 | 03:55 PM
laythor's Avatar
http://www.emergencyresponderproduct...oadflares.html
just buy some standard ones and dip them in different chemicals.. i'm sure you'll get blue somehow :wink:
Old Apr 29, 2007 | 08:02 AM
Landon's Avatar
Blonde Bastard
I had a set on my 8 and you can run the cables up the sides like the previous poster said. I zip tied them to cables and lines already running under the car so they stayed well hidden. Its also easy to protect the lights except for the tube on the front so keep that in mind. There is no place to tuck the light that mounts on the front underbody so it will eventually be destroyed like mine was. The sides I tucked inside the MS side skirts and put the rear behind the heat shield of the exhaust.
Edit:
Here is a pic of it when I had them on my car..
yapakanichi
Aug 25, 2015 01:24 PM
EfrainOlivares
Aug 14, 2015 06:17 PM
Stubbs
Jul 28, 2015 09:23 PM
AussieGray
Jul 16, 2015 03:58 AM
