2004-2006 Mazda RX-8 Wire Colors & Locations
Old Apr 22, 2007 | 07:42 PM
SBZRO's Avatar
Wire/Function Colour Location/Description Polarity
12 VOLTS Yellow Ignition switch harness +
IGNITION Black/yellow Ignition switch harness +
ACCESSORY White/red Ignition switch harness +
STARTER White/blue Ignition switch harness +
KEY SENSE Pink/black Ignition harness +
TACH SIGNAL Opposite from Black and Black/white At any of the 4 coils on engine
FUEL INJECTOR opposite from White/blue At any injector on engine
LOCK Lt.green In driver's kickpanel -
UNLOCK Lt.green In driver's kickpanel -
DOORPIN Green/black In driver's kickpanel -
TRUNK PIN Brown In driver's kickpanel -
TRUNK RELEASE Yellow At release switch in dash -
FACTORY ARM Green/red In driver's kickpanel harness from door -
FACTORY DISARM Green/red In driver's kickpanel harness from door -
BRAKESWITCH Black/blue At switch above brake pedal +
PARKLIGHTS Black/red In driver's kickpanel +
HAND BRAKE Gray At switch on handbrake lever -
HORN Green/blue At steering column -
DRIVER WINDOW UP Yellow/green At switch in driver's door Rev Pol
DRIVER WINDOW DOWN Red/black At switch in driver's door Rev Pol
PASSENGER WINDOW UP Lt.green/black In driver's kickpanel Rev Pol
PASSENGER WINDOW DOWN Green/white In driver's kickpanel Rev Pol
VSS WIRE Green/red Radio harness
This is the best I could do for now. I'll get the radio wiring harness colors up soon.
SBZRO's Avatar
Can anybody make that a table?
Old Apr 22, 2007 | 07:59 PM
SBZRO's Avatar
I'll get the radio one up in a few minutes.
Old Apr 22, 2007 | 08:31 PM
juiceRx8's Avatar
Did u Knw Ur Grlz on my..
Already posted guys. https://www.rx8club.com/series-i-interior-audio-electronics-24/rx-8-wiring-information-104886/
Old Apr 22, 2007 | 08:50 PM
Davey's RX-8's Avatar
Red headed stepchild
Would like to see steering wheel radio controls wiring.
Old Sep 13, 2007 | 12:21 AM
Just found your post.
Im looking for the VSS wire for my coming NAV, and you said its the Green/Red wire in the Radio Harness right? Are you talking about the one I circle in the picture ?
Old Sep 13, 2007 | 07:35 AM
Bump!
Old Sep 13, 2007 | 08:53 AM
Dont worry about it, I got the wire. Search and Sticky post are my friends.
ASH8
20
Sep 26, 2022 11:55 PM
ASH8
Oct 30, 2021 12:50 PM
leavitt
Aug 4, 2015 01:55 PM
Jazzmeson
Jul 31, 2015 01:47 AM
Bamaham
Jul 23, 2015 08:08 AM
