jzief128
04-16-2007, 11:27 PM
Okay guys, I have a problem I though maybe you could help me with. I am trying to track down a noise I started hearing today. I noticed it when I was in gear and driving at speed (55 mph). It sounds kind of like a faint metallic grinding sound, coming from somewhere in the center of the car.
After much trial and error, I realized it was the transmission. In neutral I can hear the sound, while it seems to be slightly louder once I am in gear going over 45 mph or so. The odd thing is that once I push the clutch in, the noise disappears. With the engine running and the clutch in, I can go through all the gears and no weird sound. But take it out and put it in neutral, and I can hear it. Mind you, its not gear whine, as it is a completely new sound I noticed today.
Background is that I changed to the AFE SS about 2 weeks ago, which increased the gear whine (as expected) but not other strange sounds. Last weekend (4/7), I changed the transmission and differential oil to RP MaxGear 75W90 (1.9 qts. in the front and 1.4 quarts in the back), using new crush washers for both the drain and fill plugs. The only bad thing I did was not have my correct torque wrench and just tightened the plugs until they were plenty tight. I noticed an increase in notchiness in the shifting while cold, but a similar feel to stock when warm. I noticed no additional weird sounds.
The last "thing" that I did was take out and check the air filter box. When I did, I noticed I was missing one of the bottom grommets for the box, although I suspect the dealership lost it when clearing the oil out of my box for the ventilation TSB.
With all that background on what it could be, any ideas? My first is that somehow I am low on transmission fluid or something, causing the sound.
Thanks in advance.
Thanks in advance.
