Installing Fuel Pressure Sensor
Old Apr 14, 2007 | 06:35 PM
jskup1's Avatar
The Chief
Besides spending $75 after shipping for PTP's adapter, what options do I have for installing the sensor for a fuel pressure gauge?
Old Apr 14, 2007 | 10:44 PM
Charles R. Hill's Avatar
Owner of BHR
Exactly what is it you got from PTP for $75? What's their part number?
Old Apr 15, 2007 | 07:37 AM
jskup1's Avatar
The Chief
I haven't bought anything yet. Here's a link to their product. They want an additonal $20 or so to ship it.
http://www.tuningmotorsports.com/pro...age=1&featured
Old Apr 15, 2007 | 09:01 AM
Owner of BHR
That is a nice product but for that cost you are better off buying a second factory fuel line and modifying it to accept the more standard type of sensor adapter. Here's the thing with this adapter; even if you install it in-line where the red "quick-connector" fuel fitting first appears under the hood(near the brake master cylinder) you'll either have a pressure sensor coming away from the adapter perpendicular to the fuel line, which isn't very attractive and will be in the way a lot of the time, or you'll still have to get a 90 degree fitting anyway. The other option would be to mount the adapter on the fuel rail side of the fuel line so the 90 degree fitting would not be needed and the adapter/sensor hardware would be hidden out of view.
Are you just looking into installing gauges for appearance purposes or are you going with a power-adder and need the fuel gauge?
BTW, I think a more reasonable cost for this adapter would be in the ballpark of $30 USD. I say this from the perspective of one who knows how much productions costs are and how large the market could be for PTP if it were priced at this level.
Old Apr 15, 2007 | 09:44 AM
jskup1's Avatar
The Chief
I'm going FI in the fall and want to get the gauges installed pre-FI to get a better idea for tuning it. I agree on the cost being a little excessive for this. I was wondering if anyone had tried to put an adapter under the seat at the fuel pump.
Old Nov 14, 2007 | 06:01 PM
Derex'8's Avatar
ReDuX
Can a standard inline fuel pressure adapter be used?
Old Nov 14, 2007 | 09:14 PM
Derex'8's Avatar
ReDuX
Anybody?
Old Nov 15, 2007 | 07:32 AM
Derex'8's Avatar
ReDuX
Would anybody hapen to know the inner diameter of the stock fuel line?(The flexible hose part that connects to the quick connector)
Old Oct 26, 2011 | 05:44 PM
FazdaRX_8's Avatar
There has got to be someone who did this differently.
Yes there is a 60 dollar piece from summit or bhr. But you also need the spendy plug.
Has anyone just cut the line and installed a T? Or just clamped on a whole new soft fuel line with a T?
Old Oct 27, 2011 | 10:21 AM
MazdaManiac's Avatar
If you have an extra fuel rail, you can make one yourself, but it isn't really worth the effort.
Old Oct 27, 2011 | 11:49 AM
TX
The aeromotive fitting just works perfectly and is not a permanent change so it was a no brainer for me.
Old Oct 27, 2011 | 01:51 PM
This is what happens when there are too many threads on the same subject,
also when people can't spell
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/fuel-pressure-sensor-location-127893/
you will feel like a real champ if your cheap alternative results in your car catching on fire, $60 + plug, but it plugs in just like OE. Don't be stupid trying to save a dollar.
Old Oct 27, 2011 | 06:02 PM
FazdaRX_8's Avatar
Thanks team, i wouldnt have thought to search for "pressuse".
In any case, at least i didnt start a new thread.
MM, have you since switched to the adaptor, or are u still useing the softline solution?
Old Oct 27, 2011 | 06:20 PM
It isn't exactly a "soft line" - it is a hard hose like the OEM line.
I've just fitted connectors at either end of the "T".
Old Oct 27, 2011 | 06:33 PM
zoom44's Avatar
fixed the title of that other thread
Audio Concepts ATL
Sep 26, 2021 01:59 PM
drebbrnator
Dec 27, 2018 07:02 PM
9krpmrx8
Nov 5, 2015 11:45 PM
GracefulShanks
Aug 18, 2015 11:40 AM
megaman
Aug 14, 2015 08:41 AM
