tire install problem - damaged sidewall?
Old Apr 12, 2007 | 05:39 PM
balefire's Avatar
SCCA BS #35
I bought a used set of 19" tires that looked fine unmounted...
I just had my local tire shop mount my 19" tires this morning...
Tire installer was an idiot, installed one asymmetric tire backwards, worked on the same tire for an hour unmounting / remounting it and failed...
finally got the manager who knew what he was doing to do it...
After all was said and done, it now has a 2-3" bubble in the sidewall.
Is it possible that the bubble in the sidewall was due to the install? Or must it have happened previously since it was a used set of tires?
edit: finally added the pics
Attached Thumbnails tire install problem - damaged sidewall?-pict1517a.jpg   tire install problem - damaged sidewall?-pict1518a.jpg
Old Apr 12, 2007 | 10:12 PM
ZOOMNRX8's Avatar
Got pics? doesn't sound good...
Old Apr 16, 2007 | 10:28 PM
balefire's Avatar
SCCA BS #35
finally added pics. any ideas?
Old Apr 16, 2007 | 10:32 PM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
Yeah the bead is torn up, you can see chunks missing on the side, and the air is getting in the sidewall. Pull that tire off and I bet most of the inside of the bead is gone. I would not drive on that. No doubt that was done by the installer/tire machine.
Old Apr 17, 2007 | 04:08 AM
did it have that missing chunk and sidewall rips before the install? If not, the tire shop owes you a new tire, otherwise somebody sold you a defective tire
xAgyex
Jun 3, 2026 03:47 PM
rotorocks
47
May 11, 2016 03:23 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
Sifu
Aug 30, 2015 10:51 PM
