Break like sound when starting to move with 1st gear
Old Apr 12, 2007 | 01:37 PM
rotaryPilot's Avatar
Exclamation Break like sound when starting to move with 1st gear
Hi all,
Well apart from my differential noise which I solved thanks to you there is still one more issue concerning strange sounds in my RX. Let me give you some details:
        I went to the dealer and two people drive tested and reproduced the sound but they had no idea where was coming from. They only lifted the car and checked the engine mounts that they found to be ok.
        Thanks a lot guys for your time and once again congratulations for this powerful club you have.
        Old Apr 14, 2007 | 12:21 AM
        dastallion951's Avatar
        perhaps it might be ur one of the fingers on ur pressure play is bent...... or ur shift fork in ur trans might be bent.......? have them unbolt trans from engine n visually inspect
        Dokuji
        Nov 1, 2016 02:51 PM
        WingleBeast
        22
        May 23, 2016 09:22 PM
        uZu
        Dec 30, 2015 12:35 PM
        madrotor
        Jul 26, 2015 12:06 PM
        dbarber
        Jul 25, 2015 01:34 PM
