Clutch Pedal Throw Adjustment
Old Apr 7, 2007 | 09:12 PM
Phlash's Avatar
Go Speed Racer, Go!
Anyone???
Old Apr 8, 2007 | 03:56 AM
10mm and a 12mm wrench. you need both..
behind the pedal..
Old Apr 14, 2007 | 07:50 PM
Phlash's Avatar
Go Speed Racer, Go!
K...let me finish it now.......
These are the two bolts that are on the rod that connects to the clutch through the firewall. They are behind and at the top of the pedal.
Loosen the 12mm....now with your hand, if you're laying on your back looking up at this and holding it from the top of the bolt, twist the smaller 10mm bolt to the right (toward the foot stop). You'll see that the end of the bolt is moving toward the back of the clutch pedal. The more you move that bolt towards the pedal, the closer to the floor the cluth will engage. Make sure you have some play in the top of the throw. I think the shop manual has it at something like .2 inches.....not a lot. Needless to say to pull the clutch engagement away from the floor, twist the 10mm to the left and the bolt head will move toward the firewall. Fire it up and check to make sure your happy with the catch point and then tighten the 12mm back up, just snug. Not too tight or you may break the clutch bracket.
Here is another link to someone else's instructions........
https://www.rx8club.com/showpost.php...3&postcount=64
Please feel free to add anything I missed................
mdl0209
May 23, 2019 05:46 PM
tommy26Germany
Sep 29, 2015 10:33 AM
GARCIAC951
Sep 10, 2015 07:17 PM
Anthony Kevin
Sep 7, 2015 07:36 PM
