Pics: Magnecor Competiton KV85 wires & RX7 Spark Plugs
Old Apr 6, 2007 | 09:01 PM
staticlag's Avatar
The Professor
Well, tested my coils and they tested bad. So I was going to go to the dealership and have them replaced under warranty, but I really didnt want the dealership to reflash my engine computer and reset my RB flash. So I just decided to buy new coils, plugs and wires myself.
And boy, it was a good thing that I did.
RX7 Plugs: They are NGK BUR-7EQ leading and BUR-9EQ trailing.
Magnecor KV85 wires:
Installed:
OLD plugs & wires Notice the corrosion:
Old Apr 7, 2007 | 12:39 AM
Im going to replace my plugs and wires next monday, but my wires are RB.
Then Im going to start a thread just like yours.
How does the 7 plugs feel ?
Old Apr 7, 2007 | 10:39 AM
staticlag's Avatar
The Professor
the 7 plugs feel good. Idle is good. I am pleased with the purchase. The plugs were a total of $16 at O'Reilly Auto parts.
Old Apr 8, 2007 | 09:51 AM
rx7speed's Avatar
whats with the little bar on the top of the plugs for?
Old Apr 8, 2007 | 10:14 AM
staticlag's Avatar
The Professor
On the stock plugs?
Old Apr 8, 2007 | 11:02 AM
chickenwafer's Avatar
Nope
****, only $14 for new plugs! RX8 specific plugs are over $140!!! Hello RX7 plugs, here I come!
I'm thinking of the RB Ultra 8mm plug wires, new coils, and plugs.
Old Apr 8, 2007 | 11:05 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
I have the RB Ultra 8mm wires and really like them..............you'll be happy. Let me know if you find some good price on the coils!
Old Apr 8, 2007 | 11:17 AM
rx7speed's Avatar
Originally Posted by staticlag
On the stock plugs?
yeah. I know my 7 doesn't have them but then again I'm using the same NGK's as he bought except maybe heat range.
and if I remember right on the 7 all the stock ones are just a perfect ring without the little grooves but I have never seen one with the bar on the stock so didn't know what it would be for on your 8's
Old Apr 9, 2007 | 11:28 AM
Nubo's Avatar
Lubricious
Actually those OEM plugs look like they are in great shape -- at least the part that matters (looking at the center insulator - nice tan color). The little crusty bits on the rim are just from the normal rotory oil burning, and aren't "corrosion". The bit of actual metal corrosion on the boot end may be from some moisture intrusion. Some dielectric grease between the spark plug insulator and the boot can help prevent that, and also makes it easier to remove the boot down the road. Also, don't forget a bit of anti-sieze compound on the plug threads. If you didn't use any, it's worth your while to pull the plugs and put some on.
You mean the center electrode?
Old Apr 22, 2007 | 12:27 PM
staticlag's Avatar
The Professor
update:
https://www.rx8club.com/showpost.php...&postcount=301
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
uZu
Dec 30, 2015 12:35 PM
GK1707
Dec 2, 2015 10:01 AM
Psychofox
Aug 20, 2015 04:48 AM
