o2 sensor question
Old Apr 3, 2007 | 05:50 PM
davidwanj's Avatar
o2 sensor question
for those who have a testpipe....I was wondering how did you guys take care of the o2 sensor problem........
without the cat wouldn't the o2 sensor(mainly the downstream one, not the one near the header) give a bad reading and fry the engine?? I know they have o2 sensor simulator out there....but can't really find one that's FOR rx8 nor do we know if the simulator is 100% accurate............as far as I know the o2 sensor calculate the amount the oxygen in engine and adjust the amount of gas and stuff inside the engine.....unless I am wrong and the only thing it does is turn off your CEL
if the o2 sensor failed then I would fear that engine may misfire and things.....without the cat I don't know how long the sensor can last...
david
Old Apr 3, 2007 | 06:12 PM
staticlag's Avatar
The Professor
The exhaust has two o2 sensors, one in the manifold which is the wideband used for the engine to tune itself. And the other is a narrowband after the catalytic converter. The CEL is caused by the second sensor triggering that your cat is dead and has nothing to do with performance.
Not much you can do so far to get rid of the CEL, I have been running it for 400 miles so far and it doesnt bother me that much anymore.
Old Apr 3, 2007 | 06:13 PM
rg200amp's Avatar
gr8ness
put your sun glasses on her come some flames. . . .
the light will come on, no it will not harm anyhing, just go to autozone every month and get ur codes read for free to see if it throwing any other codes
the o2 sims do not work, the rare one that do dont for long. . . . . .
try the search
gwailo
May 14, 2024 06:57 AM
TJSiegrist
Sep 10, 2015 09:29 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
tgaffner
Aug 20, 2015 10:55 AM
