List of compatible oil filters
Old Apr 2, 2007 | 02:47 PM
Daishi's Avatar
List of oil filters that will fit the 8:
AC Delco PF2135
AMSOil SMF103
Bosch 3300 (2.5) Bosch 3323 (3.25)
Carquest 85358
Fram PH6607
K&N 303 and 303c (chrome)
Mobil 1 M1-108 (2.5) Mobil 1 M1-110 (3.25)
NAPA Gold 1358
Purolator PL14612 (2.5) PL14610 (3.25)
STP SMO 17
WalMart SuperTech ST7317
WIX 51358
NOTE: (2.5) & (3.25) = inches long
I copied this list from the Yamaha FZ6 forum on Sportbikes.net. The FZ6 (same basic engine as R6) uses the same filter as the RX-8 (as is stated in several other posts on this forum). I have an '05 FZ6 and just got an '07 RX-8. Original post located here:
http://www.sportbikes.net/forums/sho...75#post1788575http://www.sportbikes.net/forums/sho...75#post1788575
I haven't seen a list (all in one thread) of all the compatible filters on this forum yet and I wanted to contribute. Feel free to add others to the list that aren't mentioned here.
Old Apr 2, 2007 | 02:55 PM
StealthTL's Avatar
Metatron
Cool Nice....
Good list, very useful.
S
Old Apr 2, 2007 | 03:20 PM
MazdaManiac's Avatar
K&N HP-1010
Old Apr 13, 2007 | 01:26 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Nice list!
Old Apr 15, 2007 | 04:20 AM
User24's Avatar
I called NAPA and they claim to stock the WIX 51358. However, on their store computer system it is not listed as an RX8 compatible filter. A check on NAPA's website reveals the fol for the 2005 model year:
Oil Filter (ProSelect): SFI 21365
Oil Filter (NASCAR): NFI 91365
Oil Filter (Gold): FIL 1365
Oil Filter - K&N Filters: BK 7355557
When I walked into the store and asked for a Wix filter, they handed me a NAPA Gold 1365. As explained by a store assistant, the NAPA Gold is "thicker" than the Wix.
I have always bought Mazda filters, but as of late, due to work hours I am physically unable to purchase a Mazda filter from the dealership. A little rx8clubbing revealed that RG uses Wix, so I began searching for Wix alternatives to OEM.
Well, it's a good thing I have a quick-drain plug, so no need to buy any OEM crush washers. This means I can try to fit the NAPA Gold 1365 tomorrow. There is no mention of the 1365 on rx8club, until now. Maybe this is for rx7 and their computer is wrong?
Please click these text links for the photos. Clicking on the thumbnails will do nothing for you, because I am hosting the higher res photos.
1. NAPA 1365 Box
2. 1365 description
3. 1365 Filter Bottom
Attached Thumbnails List of compatible oil filters-1365_box_th.jpg   List of compatible oil filters-1365_internal_th.jpg   List of compatible oil filters-1365_filter_th.jpg
Old Apr 15, 2007 | 09:06 PM
User24's Avatar
The NAPA Gold 1365 worked. Both OEM and 1365 were the same height and the o-rings were the same diameter. 1365 looked like it had 1 more set of threads however.
Old Apr 15, 2007 | 09:14 PM
I get the WIX at O'Reilly's.
Old Apr 16, 2007 | 10:38 AM
savedsol's Avatar
Carbonormous
Wixfilters.com lists the oil filter as 51365
Here's the spec sheets for each...
http://www.wixfilters.com/filterlook...asp?Part=51365
http://www.wixfilters.com/filterlook...asp?Part=51358
If you don't want to click here is the differences between the 51365 vs 51358
Height - 2.57 / 2.78
OD - 2.685 / 2.685
Bypass valve PSI - 8-11 / 8
Flow Rate GPM - 9-11 / 8-10
Burst Pressure PSI - 300 / 265
Nominal Micro Rating - 19 / 14
Seems like the correct filter (51365) seems like the higher grade piece.
Old Apr 17, 2007 | 10:02 PM
TKE Tails's Avatar
TKE Tails
Fram also has a High Flow filter that in my opinion is what is ideal. Check it out, and its still decently inexpensive.
My two cents.
Old Apr 29, 2007 | 07:15 PM
willrotary's Avatar
Rotary Dominican Republic
Oil Filter
I used K&N HP-1008 as appear for my rx-8 2004 at Autoadvanced autoparts
Old Apr 29, 2007 | 08:10 PM
Spin9k's Avatar
Momentum Keeps Me Going
Fram PH6607
another addition....Fram "Tough Guard" TG6607
- 99% Multi-pass filtration - SAE Test J1858 for particles >20 microns
- Synthetic glass & cellulose media
- Silicon Anti-drainback value - engine always starts w/full filter
- Bypass value w/particle screen
<$5 at Walmat
Old Apr 29, 2007 | 08:24 PM
Cody Red's Avatar
always filling [the c]up
woo, update the list.
-Cody
Old May 1, 2007 | 08:19 PM
Low Fly'n 8's Avatar
http://minimopar.knizefamily.net/oilfilterstudy.html
Old May 1, 2007 | 09:28 PM
the OP didnt update. Can I start another thread?
Actually I will do it now. Delete it if it offends anybody
Old May 2, 2007 | 10:14 AM
Daishi's Avatar
I don't plan on updating the list every time filters are added. That wasn't my original intent. If someone wants to maintain a single, constantly updated list, please go for it.
mr. GrandGame
Sep 9, 2025 10:41 PM
05TR1CH
Apr 18, 2023 04:56 AM
Warrior777
Jun 24, 2019 04:47 PM
drebbrnator
Dec 27, 2018 07:02 PM
Junirol
Sep 22, 2015 06:02 AM
You have already rated this thread Rating: Thread Rating: 1 votes, 5.00 average.
