Good ground in trunk?
Old Mar 29, 2007 | 02:22 PM
rx8guy86's Avatar
Drive Like you stole it
Question Good ground in trunk?
Before i proceed... Yes, i did read the sticky about the grounds...
My question is where are some good places to ground in OUR cars in the trunk?
What is the best route to run 0 awg wire to the trunk without interference
Old Mar 29, 2007 | 04:37 PM
rx8guy86's Avatar
Originally Posted by abbid
My question to you is what the hell are you running that requires 0 AWG?
Kicker KX1200.1 & Kicker KX850.4
Old Mar 29, 2007 | 04:59 PM
WikkedOne's Avatar
Deals on wheels
abbid - we've already went over this in his other thread, he knows it's overkill but it's not really going to do any harm.
i would run it along the passenger side door - assuming you can get it to fit in there, there isn't any other wires in there.
and as for grounds.. some people claim to have luck with some random spots, but back to the battery is defiantly the only way to go in my head for this car.
Old Mar 29, 2007 | 05:02 PM
I ran 6 guage along the passenger side door and I BARELY got the damn thing to close. It's going to be a tight fit...
Old Mar 29, 2007 | 05:03 PM
rx8guy86's Avatar
yYeah, I was able to get the kicker amp kit for the same amount of $$ as a regular 4 gauge. Right now i have the power running up thru the center console. I dont know if I can get two of the 0awg wires thru there... I know it will not go along the pass side...
Old Mar 29, 2007 | 06:16 PM
WikkedOne's Avatar
Deals on wheels
you barely got a 6 to fit?
I ran two 4 AWG (power and ground) through the driver side, with all the regular wires that are in there. Granted i had to cut out those plastic tab things, but it all fits..
have you tried the door thing without those plastic holder tabs? maybe you could do one in the center and one in the door, or down each side of the center.
(this is why you don't use 0 AWG unless you are going from your 4 batteries in your trunk to your Dist. block less than a foot away)
Old Mar 29, 2007 | 06:30 PM
I ran two 6guage in there and it was one hell of a tight fit to get the thing to clip back into place.
Old Mar 29, 2007 | 07:05 PM
rx8guy86's Avatar
As it stands, I have it grounded to the bolt in the floor right next to the rear right shock. Should that be ok?
Old Mar 29, 2007 | 08:10 PM
jstkilntim's Avatar
resU deretsigeR
My 2 gauge JL power wire fit easily along the passenger side under the white clips. I think forbidden ran (2) 0 gauge down the passenger side.
I currently have my ground at one of the bottom mounting bolts of the back seat w/ no problems, however, I still have small amps.
Old Mar 29, 2007 | 08:50 PM
rx8guy86's Avatar
for the record, 0gauge will flow 8000 watts peak and over 3k rms..
talk about OVERkill.
I know its overkill.. I had the option to guy 4 gauge or 0 gauge kit for the same price.. now im kinda kickin myself in the *** for doing it... lol
BigMikeATL
May 26, 2016 12:31 AM
garaxy
Aug 23, 2015 07:04 PM
D13
Aug 22, 2015 11:42 PM
