CEL this morning.
Old Mar 28, 2007 | 07:54 PM
DarkBrew's Avatar
Extraordinary Engineering
CEL this morning.
The CEL came on this morning when I started my car.
I stopped by the dealer and it turned out to be the gas cap which was replaced under warranty.
Apparently they use smoke to test this...
Old Mar 28, 2007 | 08:05 PM
dillsrotary's Avatar
jersey fresh
ditto, i just had it done for my cx-7 darkbrew. I didn't see a 'smoke' test though
Old Mar 28, 2007 | 11:26 PM
DaveCM203's Avatar
DaveCm
Same here. I just picked my car up yesterday for a cell. They replaced the gas cap and everything seems ok so far. It was under warranty also.
Old Mar 29, 2007 | 04:44 PM
corners's Avatar
An RX ate my baby
Last time I went in to have my tires rotated the dealer replaced my gas filler neck and cap as a recall item. It wasn't throwing a CEL but there must have been problems.
Old Mar 31, 2007 | 12:14 PM
ken-x8's Avatar
The TSB for the gas cap (MSP13) specifies that the cap should be replaced based on the car's VIN. No tests, and they even say that they will not cover any additional diagnostics.
Ken
Old Mar 31, 2007 | 12:25 PM
DarkBrew's Avatar
The tech at my dealership wants to prove there's something wrong before they replace something and not just replace a part because there's a TSB.
I understand the approach but it can be frustrating to go there to hear that they can't find a problem, then demonstrate it to them then bring it back so the tech can have another look to confirm then wait for the part then bring it in again for the install...
But the gas cap CEL was one trip last summer to clear the CEL and this week to clear the CEL and replace the cap.
Old Mar 31, 2007 | 12:30 PM
Easy_E1's Avatar
I wouldn't want to be the guy who had to smoke by the gas filler/cap.
j/k
I like it when they (dealer) can actually fix something on the first visit. Not 5 visits later. Not every time you go the problem "Cannot be duplicated".
God I hate that.
Old Mar 31, 2007 | 01:05 PM
LouisvilleREDrotary's Avatar
Hey easy e1 im a master tech at a mazda dealer whats your problem, i might have seen it before
Old Mar 31, 2007 | 07:02 PM
Easy_E1's Avatar
Looks like your in Lousiseville and I'm in Phoenix.. Long way away to hear a ticking from the back window.
I have a Master Tech where I take my car. But it never makes the sound when I take them for a test drive.
Drive over here and listen for it.
Old Apr 1, 2007 | 07:57 AM
two rotors's Avatar
I would be taking my car somewhere else if my gas cap was tested this way!There is a set of diagnostics built into the WDS which tests the Evaporative emissions control system.If you wanted to test the gas cap alone,there is a simple vacuum tester(used when you take your car for the smogg test).
Old Apr 1, 2007 | 02:07 PM
Apparently they use smoke & mirrors to test this...
fixed it for you
Old Apr 1, 2007 | 02:14 PM
DarkBrew's Avatar
Originally Posted by TeamRX8
fixed it for you
Thanks. I really needed more reasons to be worried when I leave my car with them.
theblinkof
Oct 4, 2023 05:24 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
Evan Gray
Sep 26, 2015 12:30 PM
Forevermore
Sep 20, 2015 01:04 PM
