Fuel Cleaner How To?
Old Mar 27, 2007 | 10:39 PM
Targatheory's Avatar
I've read most of all the search results on this matter. My question is, what is the best way/procedure to use these fuel cleaners? Should I run my car till it's empty on gas before I add any fuel cleaner? Should I use the highest possible octane rating gas (93) from like a toptier pump with the cleaner? What do you guys recommend as the optimal fuel cleaner that is locally available (ie, not by ordering online). Thanks.
Old Mar 28, 2007 | 12:27 AM
Old Rotor's Avatar
Do what the directions say on the bottle or can. When you say "fuel cleaner", what are you trying to clean, moisture,injectors,carbon deposits? What problem are you haveing or do you just want to do some preventive work?
Did you read this one?
https://www.rx8club.com/showthread.p...6&page=1&pp=15
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
urbanvoodoo
Sep 30, 2015 12:41 AM
RotaryMachineRx
Sep 29, 2015 10:26 PM
DeltaJ802
Sep 29, 2015 01:20 PM
Evan Gray
Sep 26, 2015 12:30 PM
