is 18x8.5 +30 235/40-18 fit ????
Old Mar 27, 2007 | 06:04 PM
kinkyfly's Avatar
does anyone know 18x8.5 +30offset, 235/40/18 tires fit without rubbing fender?
Old Mar 27, 2007 | 10:51 PM
ac3mastuh's Avatar
Got Ings?
yeah it should fit since I've seen people fit 275's with 9.5 rims with a +45 offset.
275-235 = 40 (tire overall width) (narrower)
40/2 = 20 (tire width per side) (narrower)
45-30 = 15 (since your tire is 20mm narrower and your offset is only 15mm lower it should fit with no problem. hell you could even run a 245 tire if you wanted)
Old Mar 27, 2007 | 11:09 PM
http://www.1010tires.com/WheelOffsetCalculator.asp
they will fit, but they are going to be way to the outside of the car...
Old Mar 28, 2007 | 09:31 AM
ac3mastuh's Avatar
Got Ings?
would they be?
i mean I think my math is right so it shouldn't stick out any more than the guys running 275's all around
Old Apr 3, 2007 | 06:40 PM
Im_DANomite's Avatar
I love GOOOLD
i have 18x8.5 +30 with 235/40R18....it's flush. no modification needed...even with the car lowered.
Old Apr 4, 2007 | 07:00 AM
L8APEX's Avatar
Smooth Criminal
rather than start a new thread, what about a 265/30 on a 19X9.5 wheel, with +35 offset. the car is on coilovers too, so it sits lower than stock. I am test fitting them this weekend, but just curious.
Old Apr 11, 2007 | 11:36 PM
LionZoo's Avatar
road warrior
9.5" should fit perfect.
Old Apr 12, 2007 | 12:05 AM
Easy_E1's Avatar
The outer edge of the rim will be 26mm farther to the outside than stock. Go from there.
Old Apr 12, 2007 | 12:09 AM
LionZoo's Avatar
road warrior
Oops sorry. I meant 9.5 should fit the tires perfectly, but I think they'll rub.
Old Apr 12, 2007 | 03:35 AM
c41250n's Avatar
they will fit and they wont rub!
Old Apr 12, 2007 | 06:04 AM
L8APEX's Avatar
Smooth Criminal
well, they are on the car. they fit, and do not rub...yet. I think I am going to roll the rear fenders, just to be on the safe side. if the rear suspension compressed all the way, say on a freeway on ramp, they would rub more than just a little. so, time to roll some fenders.
Old Apr 12, 2007 | 09:08 AM
savedsol's Avatar
Carbonormous
Pics?
Old Apr 12, 2007 | 09:10 AM
L8APEX's Avatar
Smooth Criminal
sorry, had not gotten to that point first thing this am, had to let the sun come up.
car is dirty, it will get washed and shined tonight.
Old Apr 12, 2007 | 12:21 PM
Dinhx8's Avatar
My Rex goes to 11!
looks good- are you the same size/offsett on all 4s?
Old Apr 12, 2007 | 12:25 PM
L8APEX's Avatar
Smooth Criminal
no, IIRC, +42 on the front, and +35 on the rear.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
hufflepuff
May 30, 2016 10:45 AM
Quiggs321
Sep 30, 2015 05:34 PM
GranTouTou
Sep 30, 2015 06:11 AM
GK1707
Sep 27, 2015 07:33 PM
