RICHARDS108
03-27-2007, 02:52 PM
Ok now im sure this has been asked b4 and I have done a couple quick searches to see if there were any threads on the matter but I can seem to find any. I bought some new from turn signal bulbs I don’t know how to install them I just was wondering if anyone could help me out with some info
Thanks everyone
RICHARDS108
ac3mastuh
03-27-2007, 05:03 PM
Easiest way if you've never done it before would be to lift the front of the car and take the wheel off. Then remove the front liner and the bulb should be there. Just turn it 1/4 turn to the left and replace.
RICHARDS108
03-28-2007, 04:50 PM
sweet that sounds easy enough thanks for the info
RICHARDS108
Jedi54
03-28-2007, 04:52 PM
did you get Stealth Bulbs?
brsflorida
10-04-2008, 06:19 PM
Looking for way to change front Turn Bulbs to Chrome -- I Have Bulbs -- Is this the ONLY way to get to those bulbs?
Seems like a lot of work to get to a bulb?
laythor
10-04-2008, 06:29 PM
easiest way is to simply reach in and turn the post holding the bulb in place.
the drivers side is very easy to get to, the passenger side requires you to take off the ecu cover.
Blazed
10-04-2008, 09:51 PM
I have done this before and i did not need to remove the wheel. Simply turn the steering wheel all the way right or left, depending on which side you are working on. That gives enough room to remove the front liner and change the bulbs.
brsflorida
10-04-2008, 10:25 PM
Thanks I have a 2007 I Tryed from top -- removed fuse box cover -- no way to reach from there -- didn't bother on pass side because no way in on drivers -- but looks like turning wheel will do it -- Since my Clear corners are coming next week I'll try the wheel thing when I do thoose -- Thanks to both of you for the help
