Can't remove connector from inside door!
Old Mar 26, 2007 | 08:20 PM
MR2_Spyder's Avatar
San Diego
I couldn't remove the big electric connector thing for the door lock/window up/down components.
I am trying to find the bulb holder onmy door..... if u know what I mean, let me know.
Old Mar 27, 2007 | 05:51 AM
Go48's Avatar
Is this what you're looking for?
Attached Thumbnails Can't remove connector from inside door!-courtesy-light.jpg
Old Mar 27, 2007 | 03:32 PM
MR2_Spyder's Avatar
San Diego
once i remove the plastic lens cover- there is just a hole. There is no burnt-out bulb or bulb housing. Just a hole.
I can tell the bulb is in there somewhere because i see light.... really annoying.
Old Mar 27, 2007 | 03:42 PM
RedSheDevil's Avatar
.:. causing mischief
sounds like the bulb housing fell through. you'll have to remove your door panel to get to it.
i had to do this to install my puddle lamps, lemme see if there is an online manual to help you.
Old Mar 27, 2007 | 03:43 PM
wait, i just reread your first post...are you talking about that big white block that hooks together? if so, that was a pain when i took it apart. i seem to recall finding that i was pulling on the wrong piece
Old Mar 27, 2007 | 03:48 PM
MR2_Spyder's Avatar
San Diego
ha.. i am talking about both... my housing fell through... so I then tried to take the door panel off, and I got stuck on the step that required me to take apart that white block connector because it was IMPOSSIBLE to remove.
Old Mar 27, 2007 | 03:50 PM
ok i know what youre talking about. can you post a picture? if not, try looking at the thing again. i remember thinking "well it should come apart at this joint here just like the others" except that it doesnt.
look for a plastic tab that you can gently push in with a small screwdriver. i swear those things are put together like that just to annoy us.
EDIT: you can download a pdf of the puddle light thing here i think the piece youre referring to is in step 14 on page 8
Old Mar 27, 2007 | 04:10 PM
Go48's Avatar
These may help.
Attached Thumbnails Can't remove connector from inside door!-doorpanel-1.jpg   Can't remove connector from inside door!-doorpanel-2.jpg
Old Mar 27, 2007 | 05:05 PM
MR2_Spyder's Avatar
San Diego
Go48... that second pic helped a little... what's a fastener remover, though? i used this mini crobar thing and i think i broke one of the clips- making an already rattly door even worse.
also, the plastic housing around the nice metal door latch thing is kinda loose now. any way to make it tighter??
i wonder if this can be fixed by warranty? i have no clue why this stupid light fell through anyway.
Old Mar 27, 2007 | 05:29 PM
Go48's Avatar
Go here for the fastener remover. Cost $11.90.
http://www.matcotools.com/Catalog/to...&page=5&#38530
You probably should have had it fixed under warranty and saved yourself the grief. Live and learn I guess.
Attached Thumbnails Can't remove connector from inside door!-plastic-fastener-remover.jpg
vapor2
May 4, 2020 03:53 AM
vapor2
Sep 19, 2015 05:33 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
czr
Sep 13, 2015 11:37 AM
