LTAGFERN
09-19-2003, 10:16 AM
Generally speaking . . . how 'hot' IS the exhaust from a Wankel engine? If a Wankel exhaust is 'hotter' than exhaust from a piston engine, how 'cool' is exhaust from a piston engine?
Also, is the exhaust temperature of a piston engine relatively the same for 4 cylinder engines and 6 cylinder and so forth. Or is the exhaust temp of a 12 cylinder 'cooler' or 'hotter' than a 4 cylinder?
(I don't understand [maybe thermodynamics is involved here] how a Wankel rotary and a piston engine [both being internal combustion engines having, roughly, similar compression ratios and using the same fuel] can have different exhaust temperatures. What properties cause the Wankel exhaust to be 'hotter'?)
