Driver side window doesn't work...
Old Mar 26, 2007 | 01:18 PM
04BlackRX8's Avatar
Hey everyone,
So i'm driving thru the Throgs Neck Toll and suddenly realized my driver side window doesn't seem to wind down. I had to open my door to pay the guy. ( A bit embarrasing to see the window not working on an 8. Lol. I went to the autopart store on my break just now and purchased the green and blue fuses (15 & 30) and replaced them however the window still doesn't work.
Can anyone figure out what seems to be the problem? Would appreciate any ideas. Thank you.
Old Mar 26, 2007 | 02:40 PM
Detrich's Avatar
幹他媽!
a friend of mine had the same problem on his mazda mx-6 years ago. in his case it turned out the cable mechanism & wiring for the power window came loose and got all tangled up inside the door somehow. (wonderful ford workmanship.) if u are mechanically inclined, u might want to take apart the door and check what's wrong. otherwise, have the dealer look at it. it could be as simple as a bad motor.
Old Mar 27, 2007 | 10:57 PM
j9fd3s's Avatar
not sure if its got a relay or not, traditionally mazda's dont.
but its either the regulator or the switch
Old Mar 27, 2007 | 10:58 PM
DarkBrew's Avatar
Extraordinary Engineering
check finishlineperformance.com because I recall a TSB
http://www.finishlineperformance.com...35-04-1389.pdf
Old Mar 28, 2007 | 05:44 AM
Go48's Avatar
Here ya go. Print this out and take the car to a dealer for repair.
seb16
Sep 15, 2016 12:20 PM
vapor2
Oct 8, 2015 02:08 PM
dylan424
Aug 21, 2015 06:10 PM
SayDfuse
Aug 3, 2015 10:41 PM
MarkX
Jul 31, 2015 07:50 AM
