View Full Version : WOT Acceleration
Sparky
09-18-2003, 11:26 PM
Has anyone else noticed, but Wide Open Throttle doesn't appear to be as quick as partial throttle? I first noticed this when letting up and the end of some timed runs, the car seems to accelarate as I was lifting. Upon further investigation I was able to confirm that modulating the throttle results in better overall acceleration numbers that just gunning it.
I've had other cars where this effect was perceptible also, but not to this extent. Typically the modern ecu goes "open loop" under WOT conditions which means a rich mixture, but this MAP seems richer than most.
Anyone else confirm?
Doctorr
09-18-2003, 11:40 PM
Definately noticed myself that 3/4 throttle was faster than full bore.....
doc
tminus3
09-19-2003, 12:00 PM
I noticed it yesterday. At full throttle it seemed to hesitate just a tad bit, and when I backed off a little, it seemed to "catch" and what a launch! :-)
You know the car is very deceiving. Sure it doesn't have the torque for a fast standing start, but if you are in the right gear at the right RPM range, WATCHOUT!
Besides I noticed that the true advantage of a Rotary becomes apparent in a stoplight racing situation when you are shifting once for every two shifts the competition is making, thanks to the 9000 REDLINE!
wakeech
09-19-2003, 01:20 PM
in case anyone missed it, doctorr's topic on his post was:
Originally posted by doctorr
:cool: Pig Rich......
... and i'm inclined to agree.
blizz81
09-19-2003, 02:06 PM
Is the same phenomenon observed even after a fair amount of miles racked up on the odo?
OverLOAD
09-20-2003, 10:31 AM
after 3500 miles, I'm still getting tailpipe carbon deposits after only a few miles from a very thorough cleaning.. ie.. it's still pig rich..
mikeb
09-20-2003, 03:32 PM
do you think changing exhaust to hks or greddy when they come out will stop the black snot
syntrix
09-20-2003, 09:07 PM
I think you need an exhaust catch can for the black snot, lol.
OverLOAD
09-21-2003, 08:19 AM
I'd be more worried if changing the exhaust stopped the carbon build up.. it'd mean that it's getting plugged up elsewhere in the system.
The only thing that'll stop that 'snot' is leaning out that pig-rich mixture..
OverLOAD
Spin9k
09-21-2003, 08:32 AM
Excellent point, and shows what appears to not perform on paper, may in practice, be just what DOES work when dealing with real world situations.... ;)
