i'm soo confused!! i want a stock like ride but lowered
Old Mar 23, 2007 | 09:12 AM
turok4n64's Avatar
I Am Turok!!
i know it's probably a personal preference thing, but i cant for my life decide on a lowering set up
i originally intended to get the
MAZDASPEED Lowering Springs Set
with the
MAZDASPEED Front Shocks
MAZDASPEED Rear Shocks (2)
but now I hear about Eibachs!!!
AHHHHH!!!!
I just want a smooth stock like feel but lowered
please help
i've researched and searched and everything else and I just cant figure it out for my life
Old Mar 23, 2007 | 09:48 AM
Jax_RX8's Avatar
Got Another Rotary
If you want lowering with an almost stock ride, then you need the Tanabe NF210 (Normal Feel) springs. The springs lower the car 1.4" Front and 1.2" Rear and only increase the spring rate about 10% to compensate for the shorter spring travel. These are slightly lower than Eibachs and are softer, providing closer to a stock ride quality.
The Mazdaspeed Springs you are considering are very firm and are more for tracking/autocrossing and will significantly stiffen up your ride. Also, they only have about 0.8" drop F/R.
Also, the NF210 will work very well with the stock shocks, eliminating the need to purchase new shocks (unless yours are due for replacing anyways).
If you need to replace the shocks as well, Bilstein HD's or adjustable Tokico D-specs sound like they would suit your need for close to stock ride with the D-Specs being adjustable but more expensive.
Old Mar 23, 2007 | 10:46 AM
Aipex8's Avatar
X e p i A
I agree. Tokico D-Specs can be set to softer than stock and the Tanabe NF are near stock spring rate.
Old Mar 23, 2007 | 11:25 AM
BigRed's Avatar
w8nkel
i have h&r springs and i happen to like them alot! i think they are about the same height as the tanabe...right?
-BigRed
Old Mar 23, 2007 | 11:26 AM
Olorin2's Avatar
There's some good information above. Also, check out this thread which has spring rates and lowering heights for most of the kits sold for the RX-8. Very useful post. The Tanabes definitely seem to be one of the most conservative springs out there, if not the most, other than the stockies. I'm concerned with how much they lower the car though, since the MS sideskirts I have are already pretty low to the ground. The Tein H-techs might be a good compromise.
Old Mar 23, 2007 | 11:32 AM
snizzle's Avatar
Shakezula, the Mic Rula
I was thinking the same thing. With mspd stuff, I can't even get underneath the car with stock ride height.
Old Mar 23, 2007 | 11:40 AM
Olorin2's Avatar
Exactly! And I've already scraped the rear underside of one of the skirts on a curb. I do want to lower the front more than the rear, which is why I'm thinking H-techs.
Old Mar 23, 2007 | 11:47 AM
snizzle's Avatar
Do you change your own oil? I have to drive my car up on ramps that are super low profile and placed at the end of the driveway before it hits the grass. I need a lift.
Old Mar 23, 2007 | 11:57 AM
Olorin2's Avatar
Yeah, I change my own oil, but I'm able to just jack up the one side a little to get to the pan (I have a low profile jack that just barely clears the skirts).
Old Mar 24, 2007 | 10:59 AM
turok4n64's Avatar
I Am Turok!!
thank you so very much for these posts, i will be getting the Tanabe NF210 springs and haven;'t fulled decided on replacing the shocks yet, but if I do they will either be Bilstein HD's or adjustable Tokico D-specs.
Thanks so much, everyone!!
Old Mar 24, 2007 | 09:15 PM
CTrx8's Avatar
space for rent
if you don't mind, can you post where you end up getting them? i'm trying to find a good deal on some myself.
Old Mar 25, 2007 | 12:04 PM
turok4n64's Avatar
I Am Turok!!
sure will, will be buying stuff int he next few weeks, ill update it here when i do
Old Mar 25, 2007 | 12:07 PM
dmp's Avatar
dmp
RX8 and a Truk....
Tien Basic Coil overs - No better performance per dollar kit out there. If you havent purchased, give the tiens a fair shake. My kar rides better than stock. More firm - but not harsh at all.
Old Mar 25, 2007 | 12:35 PM
Jax_RX8's Avatar
Got Another Rotary
Here is the best deal I have found on the Tanabe NF210 Springs - $160 plus $10 shipping
http://www.performancecenter.com/pro...c+Applications
Here is the best price I have found on the Bilsteins HD's for the 8 - $411 w/free shipping
http://www.shockwarehouse.com/site/i...cted_year=2006
Old Mar 25, 2007 | 12:52 PM
turok4n64's Avatar
I Am Turok!!
wow those springs are very nicely priced!!!
their about $100 cheaper than then racing beat springs, and $100 cheaper than the mazdaspeed springs
what gives?
Old Mar 25, 2007 | 12:53 PM
turok4n64's Avatar
I Am Turok!!
Tokico D-Specs, where to get these?
Old Mar 25, 2007 | 01:00 PM
Jax_RX8's Avatar
Got Another Rotary
Here about $625 with rear adjustments (DPE is a good company and forum supporter)
http://www.dpeweb.com/ProductsList.a...oductTypeID=11
Old Mar 25, 2007 | 01:02 PM
Jax_RX8's Avatar
Got Another Rotary
what gives?
They are likely trying to move out stock they have had awhile.
Old Mar 25, 2007 | 01:33 PM
Jax_RX8's Avatar
Got Another Rotary
BTW - I have been searching out some lowering springs myself for a while, being more concerned about the lowering than any added performance, and have just decided on and ordered these NF210's today. I intend to keep my stock Shinka shocks as they are still very new and a little better than a standard sport shocks - which is fine for my purposes.
I did consider the Sprint and a few others that drop more than these, but did not feel comfortable going any lower as too much drop will not allow you to keep your stock alignment settings creating heavy inside tire wear, and would likely cause some undercarriage dragging issues.
Old Mar 25, 2007 | 03:26 PM
dmp's Avatar
dmp
RX8 and a Truk....
Or, for a few - just a few dollars more, you can get ride-height-adjustable coilovers
:D
Old Mar 28, 2007 | 03:15 PM
myriadshalaks's Avatar
rot8ing
:D
i think the coilovers are the better way to go as well. dmp, can you compare the teins to the mazdaspeed? review?
Old Mar 28, 2007 | 03:56 PM
ac3mastuh's Avatar
Got Ings?
i've never been a big fan of tein stuff but their coilovers are extremely reasonable. i recently got ohlins coilovers which cost me 2 arms and a leg but the ride quality on full soft is softer than stock and it looks awesome!
Old Apr 4, 2007 | 11:48 AM
Jax_RX8's Avatar
Got Another Rotary
Update - Got my NF210's today and have scheduled to have them installed this coming Tuesday. I will provide an update then. I too was looking to lower some while maintaining a close to stock ride/performance as I do not track or auto-x my car - thus my choice for the NF210's.
BTW - I agree that the Tein Basics are a great deal for added performance and lowering - but that was not the topic of this thread - the original question by Turok was how to lower WITHOUT changing ride quality, not how to increase performance and lower. This was also what I was looking to do.
Old Apr 4, 2007 | 03:45 PM
CosmosMpower's Avatar
1935 lbs. FTW!
Mazdaspeeds will NOT give you a stock like ride. The spring rates are nearly double and you won't like it. I'm running MS and Konis and it's double the stiffness of stock.
I'd check out racing beat for stockish feel with a drop.
Old Apr 4, 2007 | 03:48 PM
1935 lbs. FTW!
Please tell me you track or autocross the car. If you spent the money on Ohlins just to get a ride softer than stock I might throw up.
