Illumincated Shift Knob -- much brighter than all other lights
Old Mar 21, 2007 | 09:54 AM
dhallag's Avatar
Illumincated Shift **** -- much brighter than all other lights
I just installed the illuminated shift ****, with the custom boot (black with red stitching -- thanks mark from polak graphics). I noticed that the illumination is quite a bit brighter than the rest of the red lights in the car. Has anyone done anything to correct this - it would be great to have this illuminate at the same intensity as the rest of the red lights.
Attached Thumbnails Illumincated Shift Knob -- much brighter than all other lights-dsc01951_1.jpg   Illumincated Shift Knob -- much brighter than all other lights-dsc01955_1.jpg
Old Mar 21, 2007 | 03:51 PM
Icemark's Avatar
probably just add a resistor in series to the power lead for the lumination of the ****
Old Mar 21, 2007 | 04:03 PM
mysql101's Avatar
what did the boot cost you? I'd like to replace my stock one just because it makes noises as I shift.
I agree with the resistor comment... lowering the power to the led will make it dimmer and shouldn't hurt it. If you can use a soldering iron, it'll cost you about $3 to do.
Old Mar 21, 2007 | 04:17 PM
dhallag's Avatar
I believe the boot was around $45, well worth it. And using the forum here, it only took me about 40 minutes to replace the one there. Mark will need to know if you have the stock **** or the illuminated ****. Contact Mark at PolakGraphics: www.PolakGraphics.com; Mark87G@comcast.net.
WranglerFan
May 31, 2022 07:51 AM
WranglerFan
Nov 5, 2017 09:35 AM
Vedivan1
Sep 20, 2015 04:39 PM
erikcamacho15
Sep 12, 2015 11:23 AM
