I think my car is pinging.
Old Mar 17, 2007 | 06:34 PM
unreal89's Avatar
I don't mind pistons
I think I heard my car was pinging at over 6k rpms. I have the upgrade kit installed with no blocking plate, so I think the tune may be too lean for my setup. Does anyone here have a map for the EMU w/o a blocking plate? Also, I'm only boosting just under 6psi. I'm also running 91 octane. I don't want to get it tuned because thats a waste of money because I'm going to get a boost controller soon. Any advise? Thanks.
Old Mar 17, 2007 | 06:38 PM
Go buy a tank of 101 race gas and see if you are still pinging.
Old Mar 17, 2007 | 06:43 PM
rotorocks's Avatar
RotoRocks Powered
Get it tuned regardless, or if it pings and you don't know how/want to tune it, then stay the hell out of boost for the time being.
Get all the things together first then tune it.
Your other option is to ignore what I say, and keep boosting hoping that the ping goes away...
Old Mar 17, 2007 | 07:26 PM
rkostolni's Avatar
Pull 2 degrees of timing around that rpm point and see if you still hear it. If so pull 2 more. If its still there and your afr is 11.0-11.5, its probably not ping. If you don't have an AFR meter stop boosting until you buy one.
Old Mar 17, 2007 | 07:39 PM
chickenwafer's Avatar
Nope
Listen to this guy.........
Old Mar 17, 2007 | 09:15 PM
mysql101's Avatar
get it tuned now. the boost controller will help spool up times, among other things, but your tune will not be wasted getting it tuned before you have the boost controller installed. So there isn't any reason to wait.
e.g; my tune works on my car if my boost controller is turned off, set to 6 psi, or set to 12 psi..
Old Mar 18, 2007 | 11:35 PM
unreal89's Avatar
Well, I talked to an expert (well not really, but he likes to think he is ) and he said that the cheap 91 octane i have is worse than, say shell 91 octane. So I'll fill up on that and have another go at it.
In the mean time, anyone have any recommendations for shops in Sacramento to get this thing tuned?
Old Mar 19, 2007 | 02:24 AM
MazdaManiac's Avatar
Why are you driving an untuned turbo setup on a rotary motor and without an A/F gauge?
So, I take it that the abuse you subjected yourself to during the install wasn't nearly enough and now you want to learn how to swap in a motor as well?
Old Mar 19, 2007 | 04:04 AM
RX8PDX's Avatar
OT: those pics MM...... do these girls live with you?
Old Mar 19, 2007 | 07:32 AM
MadDog's Avatar
Consiglieri
A fool and his Renesis are soon parted.
Old Mar 19, 2007 | 07:36 AM
VarneyMazda's Avatar
Northeast Pimpin'
ditto!
i say a tune is alot cheaper than buying a new motor..
Old Mar 19, 2007 | 09:05 AM
unreal89's Avatar
I have the lc-1. the afr is 11-12 under boost, so i think it might be the timing.
Old Mar 19, 2007 | 09:41 AM
MadDog's Avatar
Consiglieri
Well, then. Do something about it!
Old Mar 19, 2007 | 02:32 PM
rotarygod's Avatar
Yeah, get it tuned! Tuning is not a waste of money. Building a new engine because you wouldn't get it tuned when you heard detonation IS a waste of money. You could potentially doing permanent damage to your engine RIGHT NOW even though it may not show up immediately.
Old Mar 19, 2007 | 02:46 PM
MadDog's Avatar
Consiglieri
^ agreed. I think a lot of people have cracked seals and never know it.
Old Mar 19, 2007 | 08:26 PM
SlideWayz's Avatar
RX-8 = Japanese MG
Well, I wouldn't say 'never know it'
...when the engine grenades, they'll know it all too well (my voice of experience)
Old Mar 19, 2007 | 08:52 PM
unreal89's Avatar
well, i haven't heard any pining since and I'm not 100 percent sure that it was to begin with. It was probably a false alarm, because there were a lot of other noises that came from outside. I was just a bit paranoid because one thing after another went wrong during my install and so I just didn't want to take any chances. I basically wanted to know if there is anything I could do to reduce the chance of knocking. Cold plugs and more expensive gas seem like the only quick fix type things I can do. I ordered a couple gauges today (AFR and Boost) and after that I will save up for a boost controller.
Thanks for the replies guys, and I really hope my motor stays in the car for a couple more years.
Old Mar 20, 2007 | 12:35 PM
MadDog's Avatar
Consiglieri
I said 'cracked' not 'blown'. The engine is perfectly capable of running with cracked seals. You might not ever know it, except perhaps for hard starts. It will run just fine on cracked seals until something else causes them to blow out. Then, you'll know it. (my voice of experience)
Old Mar 20, 2007 | 12:41 PM
rotarygod's Avatar
A seal can have a stress fracture in it somewhere but still seal just fine. It doesn't have to have lowered compression to still have a problem. A stress fracture could show up at anytime. It may be under boost or it may be just easy cruising down the street when the seal finally lets go. You never know.
Old Mar 20, 2007 | 12:47 PM
^^ Been there, done that.
Old Mar 20, 2007 | 03:30 PM
shaunv74's Avatar
Power!!
I can't help but think there is a double meaning to where you are pointing...
Old Mar 20, 2007 | 03:45 PM
MadDog's Avatar
Consiglieri
more like a triple entendre! yeah!
Old Mar 20, 2007 | 06:52 PM
SlideWayz's Avatar
RX-8 = Japanese MG
Dude,
MM & RotaryGod are two of the most knowledgeable people here, and they're both telling you you're an idiot if you don't get your car tuned. So, I'll add my small voice to their thunderous din:
"you're a total idiot if you don't get your car tuned"
Old Mar 20, 2007 | 06:59 PM
Not a total idiot. A total idiot would deny that tuning has to be done at all.
Unreal accepts that it needs to be done, but his time line is, once again, being dictated by his impatience.
That just makes him impetuous, not stupid necessarily.
