Shift Kit
Old Mar 8, 2007 | 09:34 PM
jordanjerome's Avatar
ruthless8
Shift Kit
Hey does anyone know if there is a shift kit or aftermarket torque converter for the AT?
Old Mar 8, 2007 | 11:15 PM
09Factor's Avatar
Original Turbo 'd Auto !!
https://www.rx8club.com/showpost.php...97&postcount=8
Old Mar 9, 2007 | 07:26 AM
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
Keep us informed about the pressure riser. I am also interested in firming up the shifting and already have trany coolers (2).
Old Mar 9, 2007 | 11:12 AM
ruthless8
how are the tranny coolers working for you?
Old Mar 10, 2007 | 01:28 PM
Phil's 8's Avatar
Living in the warm weather of Vegas I knew that I needed some trany cooling help so I added the first one - after 3000 miles I checked the fluid and found that it had a slight smell of burning. I added a second cooler and that solved the problem so then I added the RP fluid. Keeping in mind that I drive the 8 very hard in some very hot temps the results have been great. I now have the interceptor x and have raised my shift limits up and am sure I need additional help. The pressure riser should make the shifts more positive. I may need a larger radiator (and torque converter) if the effect is what I am hoping for.
Old Mar 11, 2007 | 11:35 PM
09Factor's Avatar
I may find out how well the shift kits works soon. The banana got a new gift today.
Old Mar 12, 2007 | 12:04 AM
N rider89's Avatar
^NieL
oOOoOoO
Old Mar 12, 2007 | 10:09 PM
llzjayarzll's Avatar
meow
updates now!
Old Mar 12, 2007 | 10:16 PM
Easy_E1's Avatar
WHAT DAVE,,WHAT????? Don't keep me in suspense.
Old Mar 13, 2007 | 01:45 AM
N rider89's Avatar
^NieL
i love new news about a/t improvements
Old Mar 13, 2007 | 09:25 AM
ruthless8
I did not know that interceptor x had anything for the AT. I met a guy today who had the greddy turbo on his AT 8 and he said he had to have it tuned, but overall he loves it. He is only pushing 5psi but he is pushing 300whp. I did not get into what other mods he has but thats not bad at all.
Old Mar 13, 2007 | 11:19 AM
09Factor's Avatar
Soon my friend, Soon. .
I don't want to spoil the surprise.
Would that be Rick from Rick's Rotary? 300WHP seems a little high for the amt of fuel the inj. can supply. Unless he put some massive ones in.
Petits SC is only making 210 whp with the stock inj. at 6 psi.
Old Mar 13, 2007 | 12:23 PM
ruthless8
I think he was running NOS as well like I said I am not sure what other mods he had done but yes he even showed me the results from his dyno.
Old Mar 16, 2007 | 10:32 AM
meow
09 needs to report!
Old Mar 16, 2007 | 03:03 PM
09Factor's Avatar
Here's my report.....
Nothing new. Sorry. maybe i'll get some time this weekend to finish, test and sometime nextweek post my results back here......
I'm normally not to secretive but I want my local friends and club members to see it first....
Old Mar 26, 2007 | 08:44 AM
Phil's 8's Avatar
Ok, in your DITY post implied that you installed the pressure riser this last weekend what's the outcome??
Old Mar 26, 2007 | 01:06 PM
09Factor's Avatar
The line pressure riser wasn't the "gift".
This was.
Wasn't trying to mislead you...
Old Mar 26, 2007 | 01:46 PM
snizzle's Avatar
Shakezula, the Mic Rula
Old Jun 9, 2009 | 06:10 PM
mdw1000's Avatar
I'll snap his neck.
Dave - did you (or anyone else) ever install and test the shift kit?
Old Jun 10, 2009 | 06:51 AM
Phil's 8's Avatar
If you find one somewhere let me know as I have been bugging the different manufacturers and all I get is "we are working on it" or a "maybe soon"
Old Jun 10, 2009 | 11:22 AM
mdw1000's Avatar
I'll snap his neck.
It would definitley be helpful to improve the shift speed. Especially the 2nd to 3rd shift near redline. That one pisses me off at every track day. I think I saw Easy complaining about it too (found a post by him in one of my searches). I have the same issue he mentioned - slow 2nd to 3rd with some slipping sometimes.
Old Jun 10, 2009 | 01:51 PM
Phil's 8's Avatar
Unfortunately you are correct. I'll call them one more time.
Old Jun 10, 2009 | 03:17 PM
09Factor's Avatar
Well I did, sort of. I bought it and installed. It was ASSumed that it would work with the 8's RC4A-EL since it was based on the 3rd gen Rx-7 R4A-EL. But the TCM's are diffrent and the valve body control is a little different also.
It does not work. The TCM is too fricking smart for our own good.
LevelTen has some interesting stuff. I like this one personally.
http://www.levelten.com/ProductDetai...AZ-JA210-3000S
Mainpage
http://www.levelten.com/SearchResult...3&Redirected=Y
Old Jun 10, 2009 | 05:01 PM
Phil's 8's Avatar
Mainpage
I already knew that the 7 kit would not work. I don't know about this Level 10 set up, got some interesting information from others on them.
Old Jun 10, 2009 | 06:17 PM
invasion08's Avatar
What info on Level Ten did you get from other people?
